Check engine light just came on, p2004 b11/4!
Old 12-29-2010, 01:05 PM
mdchaser's Avatar
01 Corvette, 05 c230, 99 Grand Am
Howdy, I've got an 05 c230k thats been running without any issues until lately. The check engine light came on and I pulled the code p2004 b11/4 which I think is an engine temperature sensor. Can anyone help me out on this one? I'm not sure which sensor it is or how to verify if it is working or not! Temps seem stable, the car hasn't overheated yet so I've been driving it (very cold around here though). Any help would be appreciated!
Old 12-29-2010, 02:52 PM
W203E35's Avatar
2006 C350 Sport 6MT
p2004 b11/4 or p2005 b11/4?
I know p2005 b11/4 is coolant temp sensor. I haven't heard of a p2004 b11/4, maybe other members can chime in.
Old 12-29-2010, 03:20 PM
mdchaser's Avatar
Hi, it is definitely p2004 b11/4, he said it was a coolant temp sensor and that there were four... Hopefully someone knows exactly which one it is, I've yet to work on this engine so I need a bit of guidance to get started
Old 12-29-2010, 05:34 PM
W203E35's Avatar
2006 C350 Sport 6MT
If it's b11/4 then the sensor is this. Very easy fix
Please see picture:
Old 12-29-2010, 06:17 PM
mdchaser's Avatar
Please see picture:
You sir are a lifesaver (not the candy)! I watched when he pulled the code and it definitely said p2004 b11/4. Do you know what the sensor is called so I can order one? Is it something that can be purchased at kragen or do I have to go through a dealer?
Thanks again!
Old 12-29-2010, 06:27 PM
W203E35's Avatar
2006 C350 Sport 6MT
Name: "Coolant temperature sensor" or "Temperature Sensor For Water Temperature"
Part Number: 000-905-07-00
Price: 10 dollars not including shipping
I doubt Kragen will have it. Try your dealer, I believe it should be no more than 15 dollars.
Here it is online (Well trusted part store)
http://www.rmeuropean.com/Part-Numbe..._A8520097.aspx
Old 12-29-2010, 06:44 PM
mdchaser's Avatar
Part is on order, thank you very much for sharing your knowledge! Saved me a lot of troubleshooting!
Old 12-29-2010, 07:08 PM
W203E35's Avatar
2006 C350 Sport 6MT
No problem, hope this sensor solves your problem
Old 09-19-2011, 10:28 AM
tghtaclegend's Avatar
05 C230
Well per my obd2 this is what came up because I go the same code on my CEL P2004: "intake manifold runner control stuck open bank 1" and so this is what I found…….
CIRCUIT DESCRIPTION
The intake manifold runner valve system is mounted on the intake manifold and consists of the intake manifold runner valve (IMRV), the IMRV motor and the IMRV position sensor. The IMRV motor opens and closes the IMRV using multiple gears. The valve position sensor detects the opening
angle of the IMRV.
The IMRV has a groove on its upper portion. When the IMRV is closed, air flows through a groove into the cylinder from the intake manifold, so that a dynamic air flow or ”tumble” air flow is generated in the cylinder. The tumble air flow drastically reduces fuel deposits inside the intake air port and the combustion wall surface inside the cylinder. This improves the combustion efficiency by boosting the air−fuel mixture and air flow turbulence.
Old 09-19-2011, 11:52 AM
Super Moderator
Glyn M Ruck's Avatar
These are Benz specific codes: See pdf. for complete list.
P2004 B2/5 (HFM sensor)(P0100)
P2004 B2/5 (Hot film MAF sensor)(P0100)
P2004 check external voltage supply.Battery voltage too high
P2004 check external voltage supply.Battery voltage too low
P2004 check external voltage supply.Control of holding relay K40/7km (relay CDI)
cutoff too early.
P2004 check external voltage supply.KI.15:hardware (HW) turn-on;CAN-BUS turnoff
P2004 check external voltage supply.Relay (diesel engine voltage supply relay) cutoff
too late.
P2004 Component N15/3(ETC control module) is faulty.
P2004-001 B18 (high pressure sensor) signal,positive/wire open cause short [P0108]
P2004-002 B18 (high pressure sensor) signal,overload short [P0107]
P2004-004 B18 (high pressure sensor) signal,engine off B28 (pressure sensor) signal
and B18 (high pressure sensor) signal different[P0106]
P2005 B11/4 (Coolant temperature sensor)(P0115)
P2005 B11/4 (refrigerant temperature sensor)(P0115)
P2005 check L5 (crankshaft position sensor).Impulse number invalid
P2005 check L5 (crankshaft position sensor).Negative rotate speed grads too large
P2005 check L5 (crankshaft position sensor).Over speed
P2005 check L5 (crankshaft position sensor).Positive rotate speed grads too large
P2005 check L5 (crankshaft position sensor).Signal interrupted while operating
P2005 check L5 (crankshaft position sensor).Signal interrupted while starting
P2005 check L5 (crankshaft position sensor).Synchronization between crankshaft and
camshaft implausible
P2005 Component N15/3(ETC control module) is faulty.
P2005-001 B11/4 (refrigerant temperature sensor),positive/wire open cause short
[P0118]
P2005-002 B11/4 (refrigerant temperature sensor),overload short [P0117]
P2005-004 B11/4 (refrigerant temperature sensor),¦Ë adaptation required minimal
engine rpm not reach [P0125]
P2005-008 B11/4 (refrigerant temperature sensor),signal error [P0116]
P2005-016 B11/4 (refrigerant temperature sensor),signal error [P0119]
P2005-032 refrigerant temperature rise too slow.[P0128]
File Type: pdf
Old 08-26-2014, 11:55 PM
dloc82's Avatar
2004 C230 KOMPRESSOR
Greetings I too have received the
B11/4 {coolant temperature sensor} Short to positive/open circuit in wiring {p0118}
And radiator cooling fan its stuck on hi revolutions in idle any recommendations. Please
advice. No other issues on car or engine management or codes present at the time. Besides
above code.
Quick Reply: Check engine light just came on, p2004 b11/4!
