Fuse/Relay Diagram?
Old 12-25-2010, 05:39 AM
tbal's Avatar
Haters crazy
Fuse/Relay Diagram?
Anyone have a diagram, pdf or something that shows what each fuse/relay is, location of the fuse/relay for our cars?
Thanks in advance...
If someone has all data or wis I think the information is available through that.
Old 12-25-2010, 08:33 AM
Bramage's Avatar
F-250
I have the PDF which shows all CAN / MOST and Fuse-Relay information, however it is in German..
I use it all the time: I just find the item in the picture, copy the german word into google translator.. shazamm If you want it, PM your email address Ill send it over
Old 12-25-2010, 11:00 AM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
OP send me your email address I will email the fuse and relay assignment in the engine caompartment to you.
Old 12-25-2010, 02:29 PM
tbal's Avatar
Haters crazy
Im more intrested in the fuses/relays in the trunk.. Any info about that?
Old 12-26-2010, 05:13 AM
tbal's Avatar
Haters crazy
thanks, pm sent
Old 12-26-2010, 10:30 AM
Bramage's Avatar
F-250
My document does not show fuel pump relay location. I went to grab the paper that is in the fuse box on the driver side of dash: Missing ARG (It was there last time i looked).. So I seached on-line, and came up with nothing. I need to get a copy of WIS. Finding things like this is so difficult.
Maybe Shardul can assist. He has helped me in the past
Old 12-26-2010, 07:41 PM
tbal's Avatar
Haters crazy
So I found this in all data...
It circles both? There are 3 relays there, which one is the correct on for the fuel pump....
If I pull the fuel pump relay and start the car, should it eventually turn off? Bad Idea?
Attached Thumbnails Fuse/Relay Diagram?-relay.jpg
Old 12-26-2010, 08:21 PM
AMGPilot's Avatar
2004 E55
One of those is a fuse holder, the other two are fuel pump relays one for each pump
Old 12-26-2010, 08:26 PM
Bramage's Avatar
F-250
I see two relays and two fuses.
Old 12-26-2010, 08:54 PM
tbal's Avatar
Haters crazy
Shows 2, but when I goto the car, there are 3 relays there...
people often replace the fuel pump relay, so do they replace both than?
Old 12-30-2010, 03:04 PM
tbal's Avatar
Haters crazy
Old 01-02-2011, 04:24 PM
tbal's Avatar
Haters crazy
anyone
Old 01-02-2011, 04:48 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
https://mbworld.org/forums/4074918-post4.html
Old 01-02-2011, 04:54 PM
Jakpro1's Avatar
Ahhh crap wait a sec. Now I found another that says it is where you showed us the pic.
https://mbworld.org/forums/4153336-post16.html
Lemme see if I can find something in Star. Gonna be awhile though. Wife wants dinner so the boss is getting dinner.
See if you can PM and Email Sneakyneon. He showed up in a couple of posts asking about it and is a wiz with a wrench. He should know.
Old 01-03-2011, 09:06 PM
reitmeid's Avatar
2005 S55 1982 300dt
[QUOTE=tbal;4429893]Shows 2, but when I goto the car, there are 3 relays there...
I have an 03 and I just got a chance look. I only have 1 relay there and no fuse. Seems like they made plenty of changes 03-06. Sorry for my previous misleading info.
So the number on my fuel pump relay is 002 542 13 19 which has been supercedes by 002 542 72 19. I found it here:
http://www.bimmerspecialist.com/usa/...42%2072%2019/3
Hope you got yours changed out ok.
Old 01-03-2011, 11:42 PM
Jakpro1's Avatar
Took me long enough but found it. Think this is what you needed no?
e55joe (03-06-2017)
Old 01-04-2011, 12:21 AM
tbal's Avatar
Haters crazy
Thank you thank you thank you!
Old 08-19-2014, 06:57 PM
A J Brutus's Avatar
Exclamation BRUTUS Real E55 fuse / relay location
In a 2004 E55 the fuse and relay for the fuel pump is on the Right side of the trunk, the fuse/relay charts published on the web are wrong and don't even acknowledge the relays on the right side behind the carpet and in front of the aromatic tank…… 30amp is fuel pump.
Old 08-19-2014, 07:27 PM
MAN55LE's Avatar
04 E55 AMG
https://mbworld.org/forums/w211-amg/...-addition.html
https://mbworld.org/forums/e-class-w...les-chart.html
Old 08-19-2014, 09:17 PM
A J Brutus's Avatar
Chart is Wrong
Hi I looked at this chart and can confirm the fuel pump fuse/relay is not as indicated, the relay/fuse in the chart is for the supercharger intercooler and is 7.5A (physically confirmed in my 2004 E55). The fuse/relay for the fuel pump is on the right side behind the carpet. I wasted time looking at the location on the chart. My friends 2005 CLS55 has the same location for fuel pump fuse/relay.
DON'T BELIEVE EVERYTHING YOU READ ON THE INTERWEB!!!!
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
Quick Reply: Fuse/Relay Diagram?
