C-Class (W202) 1995-2000: C 200 CDI, C 220 CDI, C 270 CDI, C 180, C 200 K,C 230 K, C 220, C230, C 280
Wiper not parking correctly after replacing wiper motor
Old 12-15-2010, 10:32 PM
molar's Avatar
2000 c230
I had to replace the wiper motor due to a stipped gear in the old one.
Anyway, I bought a new wiper linkage as well and thought I had installed it correctly.
I tested it before bolting the assembly down and it appeared to be parking correctly. When I put the pivot arm and wiper blade back on, it sits too low on the windshield. It actually touches the hood.
Does anyone know the solution? Anyone have pictures or a tutorial of how to get the linkage on in the proper manner? Thanks
Old 12-16-2010, 03:48 AM
Tony_AMG's Avatar
1999 C43 AMG
Will try to get some WIS Removal and Replacement description sometime before friday. PM me by Before 5PM Friday California Time PST if i haven't done by then
Old 12-16-2010, 10:21 AM
molar's Avatar
2000 c230
I was browsing another forum and a guy was having the same problem after replacing the wiper motor. Turns out it was his wiper transmission.
Could there be other causes? Want to make sure before I buy a transmission. I found one for $150 from a salvage yard. No way am I going to pay the dealer $428 for one
Old 12-18-2010, 10:33 PM
Tony_AMG's Avatar
1999 C43 AMG
Ahhhh My wiper motor took a crap earlier today since is raining here in Los Angeles. dang. Won't drive it since it won't budge. I heard it may be a nut that came loose on the motor, I'm going to inspect it on Monday since it's rainy and I park outside on the street. We'll I hope it's just that.
Old 12-20-2010, 10:14 PM
molar's Avatar
2000 c230
There is a 50% chance that the nut holding the linkage to the wiper motor backed off. If that is the case, be sure to put some blue locktite on it before you tighten it.
In my case, the motor was bad. I ordered a bilstein from autopartswarehouse.com for $95 shipped.
BTW, I finally figured out why the wiper was not parking correctly. When you tighten the two nuts holding the linkage to the motor and transmission, be sure you have the two referance marks lined up before your torque the nuts down.
Old 12-21-2010, 04:27 AM
Tony_AMG's Avatar
1999 C43 AMG
It was the nut that fell off. Anyway I put a new nut and adjusted it. On friday will take it apart and lube it up since it's still getting stuck in the middle. See how that goes. Any other issues known before I lube it up. Kind of lazy of searching ;/
Old 12-21-2010, 12:24 PM
molar's Avatar
2000 c230
If I were you, I'd take the motor plate off and look at the plastic gear to see if it is starting to get worn.
Before my wipers stopped working, they began to stick in the 12 o'clock position like yours. I took the wiper cowl off and sprayed white lithium grease on the transmission, but that did not help. A few weeks later, I heard a snap as the gear stripped, leaving the wiper parked vertically.
Old 12-22-2010, 06:12 PM
cellmaniac's Avatar
C220
Does anyone have a picture tutorial how to do this? I had the same issue with my wiper motor...all of the sudden the blade stopped moving. I do hear the motor moving. I am hoping there is a chance the locking nut came loose.
Thanks in advance!
Old 12-30-2010, 01:12 AM
eundaddy's Avatar
1998 Mercedes-Benz C43 AMG
dont put loctite on that nut.
Old 03-19-2012, 09:51 PM
jjmacj's Avatar
1999 C280
1999 c280 blade sticking in the middle of the windshield
My wiper motor was trashed so I replaced the motor and remounted the assembly. The motor is working fine, but the blade stops in the middle of the windshield. Is there an adjustment that will free it?
Old 03-19-2012, 10:11 PM
Tony_AMG's Avatar
1999 C43 AMG
You need to re lubricate the mechanism and piston. It's what happened to mine. I did it last year, hell I even replace the motor thinking that would help but to no avail. So I took off the cover on the windshield wiper, cleaned off the old lube and added the new grease lube to it. I tested it with the cover off and turned it on. Then I applied more where the lube couldn't reach when it was still and hasn't failed so far. Try that, I swear they made a thread about it, if always been an issue with this type of wiped arm mechanism.
Old 03-21-2012, 10:23 PM
99MBSport's Avatar
1999 C280 Sport
Check out this video it shows how to set the wiper to wipe the entire window .One of your adjusting bolts are lose and is slipping.
Old 03-21-2012, 10:30 PM
99MBSport's Avatar
1999 C280 Sport
http://www.202tech.com/howtos.html
Here is a page on adjustment to the Hesitant wiper assy
Quick Reply: Wiper not parking correctly after replacing wiper motor
