Laser Shifter Install
Old 01-06-2011, 08:13 PM
fusion2007's Avatar
CLS 63 S AMG , s500,clk550
sry guys for being a bit late on this install, i had to go visit family for the holidays and there on the west coast and im missouri
okay so i got under the hood today and i started looking for the firewall openings, but there is a fusebox blocking the one from the drivers side.
i would appreciate if someone could tell me exactly what to do to get to the openings, or some directions on how to properly get pass the fusebox
i also took a look on the passengers side and i could barely see the passthrough, but it was blocked by a rubber pipe.
also
for the on/off switch of install equipment is there way to send that control switch to the middle console like where the esp and unlock/lock switches are?
thanx
Old 01-06-2011, 08:20 PM
Newjd2's Avatar
2012 CLS 550 Launch Edition, 2004 CLK 500, 2004 Honda Civic
Laser shifter is a radar detector?...
Angelo
Old 01-06-2011, 08:23 PM
fusion2007's Avatar
Angelo
no, its a laser jammer which is legal in most states and it functions as a parktronic system also
Old 01-06-2011, 08:38 PM
Newjd2's Avatar
Yeah maybe I should've read the first page...
Post pics when you get it up and running and how it works...
Good luck!...
Angelo
Old 01-07-2011, 08:22 AM
  #30
2MCHCAR's Avatar
Supercharged CLK500 & ML500
also
thanx
Forget the fuse box side. Take a look again on my earlier post (and link; it has pics). Remove the battery and you'll see where other wires pass through. Remove a grommet and insert your wire.
Old 01-07-2011, 07:14 PM
  #31
fusion2007's Avatar
thanx ill do that tonight
Old 03-04-2012, 10:23 AM
  #32
BlueBuda's Avatar
2009 E63 AMG
My Install:
https://mbworld.org/forums/5085642-post6.html
Rate This Thread
Rate This Thread:
Quick Reply: Laser Shifter Install
