OIL LEAK (Photos inside)... Pls identify part.
Old 12-12-2010, 04:45 PM
speed8's Avatar
Please help me identify what part is in the ff: photos.
I haven't driven the ML550 for 2 weeks. I started her up this morning and I smelled burnt oil which I initially ignored. After pulling out of the garage, I found a small amount of oil on the floor.
Old 12-12-2010, 07:21 PM
socketman's Avatar
r
Cam plugs at the rear of the heads
Old 12-12-2010, 07:59 PM
speed8's Avatar
Socketman, what causes that to go bad and cause a leak? I'm not mechanically inclined. Im trying to learn as much before I bring it to stealership.
Is that a cross member? or a does that hold oil inside?
Old 12-12-2010, 09:32 PM
360º's Avatar
2008 ML550
looks like i am having this same problem on my ML550.
where do i look and what do i need to check to confirm that it is the cam plugs?
Old 12-12-2010, 09:59 PM
speed8's Avatar
Found this on another site:
Originally Posted by dynhm6
I believe this is the part they're replacing under the "recall" (the top part within the red box) - the camshaft case cap (part 01504). According to the service adviser at the dealership, if/when the cam cap leaks, oil can drain into the MAF, fouling it.
The part just below it is the cylinder head cap seal (part 01505), but I'm not sure it's part of the recall. I'll try to get more details when I pick the car up later today.
Old 12-12-2010, 10:04 PM
speed8's Avatar
360º, do you have the same leak as I have in the photos?
Old 12-12-2010, 10:28 PM
360º's Avatar
2008 ML550
yes exact same leak. leaking onto the crossmember on the driver side.
and my warrenty is up
Old 12-13-2010, 07:57 PM
socketman's Avatar
r
He is right 2 ways to see it look up at the back of the head from under vehicle or remove engine cover and use a mirror to look at the rear of the head to see.
You can replace them yourself, the seals just start to leak. you can pop them out with a screwdriver.
Old 12-13-2010, 08:12 PM
speed8's Avatar
I am somewhat disappointed with my ML because of this and am contemplating selling it or trading it in. I have owned other vehicles, bothe American and European, from the cheap ones to some of the expensive ones and never have I experienced something like this.
I may be overreacting to this issue but I don't expect this from MB. I've also read somewhere that this issue has been occurring a lot on the GL line.
Old 12-14-2010, 11:53 PM
360º's Avatar
2008 ML550
mine just stopped leaking. there is more than enough oil in the engine but for the past 2 days no more dripping
Old 12-15-2010, 12:35 PM
lkchris's Avatar
'07 GL320CDI, '10 CL550
This same engine is used in ALL Mercedes, and the V6 and the V8 are basically the same.
Old 10-28-2012, 03:05 AM
Saleen2276's Avatar
2007 s550
I am having he same issue with my 2007 s550,I went to the dealer and noticed all 4 plastic caps are $100 and labor $345, how hard is it to replace them myself, they kinda look like pop in plugs only
Old 11-24-2016, 07:34 PM
tritron's Avatar
cl500
I seem to have same problem at least there is easy howto
Old 11-24-2016, 08:38 PM
tritron's Avatar
cl500
There are there 3 plugs two 30 mm and one 65mm ? Does anyone knows the part numbers.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
Quick Reply: OIL LEAK (Photos inside)... Pls identify part.
