S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1992 500 SEL Speaker Wiring Problems! HELP PLEASE!! PICS
Old 11-26-2010, 10:10 PM
boss500sel's Avatar
1992 500 SEL
Unhappy 1992 500 SEL Speaker Wiring Problems! HELP PLEASE!! PICS
Hey i'm trying to hook up my stereo and the guy just said that it needs an amp but i cant figure this out for the life of me.
in a couple of minutes i'm going to take pics of the wires coming out of the dash. and the wires in the tunk.
any advice is much appreciated
thanks
Old 11-27-2010, 05:19 PM
boss500sel's Avatar
1992 500 SEL
here are pics of the wires coming out of the dash and all the wires in the trunk and i took a pic of the wires connected to the Bose amp.
Old 11-27-2010, 06:17 PM
benica's Avatar
1998 and 2002 SL 500, 2014 E550 Convertible
What are you doing...installing the original stereo or aftermarket?
If it's aftermarket.... kits are available that allow you to NOT cut into the original wiring harness and yet allow you to install a aftermarket radio.
(I see you are on line and I waited 10 minutes for your reply....I guess you got busy and I have to log out.)
Old 11-28-2010, 09:41 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
The whole system is a mess, the factory install used one of those blck plugs for antenna trigger, power, ground and dimmer. They then used a large din cable to go to the tuner mounted at the base of the rear wheel which is still there (dont know why) the output from that tuner (2pair) went to the seven channel (Bose) which fed 11 speakers. There were four in the back deck, two were tied together, one in each rear door, two in each front door, and a tweeter behind the rear view mirror, The balance was handled by the front control, and the fader was controlled by the wheel on the console. By the looks of this mess there were amps in the trunk. You have a handfull, returning to origional, or starting all over. It cant be a big job to get a head unit and then just tie it in to the wires coming from the Bose the wires for the speakers are all in looms even going into the doors.
Old 11-28-2010, 09:21 PM
boss500sel's Avatar
1992 500 SEL
there are actually 12 speakers but yes i know i'm in deep. so if i were to buy a new head unit and an amplifier to power all 12 speakers, what kind of amplifier should i buy?
Old 11-29-2010, 01:20 PM
There are 11, unless someone added another, If I were doing it I would start with a clean sheet. Check this link they talk about radios. The dash speakers were for the Cellular option, and had nothing to do with the audio.
http://mbcluster.com/
Quick Reply: 1992 500 SEL Speaker Wiring Problems! HELP PLEASE!! PICS
