HELP WITH 2002 MERCEDES CLK 430
Old 11-20-2010, 07:54 PM
mark Kelley's Avatar
Mercedes CLK430 AMG
Hi guys,
Im needing some help with my car.
Only has 68,000 miles on it when I come to a stop the car sometimes has a rough idle and when i push the gas peddle it stalls like its going to die.
Its only does this some times.
1. I have changed the Mass air flow sensor Brand New.
2. I have Changed the Cam sensor.
3. Fuel filter was changed a few weeks ago.
The car Runs Great going down the road so I do not think it's the fuel pump but i could be wrong.
No check engine Light has ever come on either.
Also I need to know the location of the Coil #5 the dealer said i had a miss fire.
Do any of you know what I should change or replace?
Im scared the car is going to die on me or get me in a wreck...
Thanks Mark
Old 11-20-2010, 08:20 PM
jimpott's Avatar
1998 CLK 320
Rough Idle/Stall
Check your engine mounts.A lot of engine movement causes some of these problems.
Old 11-20-2010, 08:32 PM
Mercedes CLK430 AMG
I have replaced them about 5,000 miles ago along with the transmission mount to.
Old 11-20-2010, 09:24 PM
Aaron68's Avatar
2005 CLK55 COUPE
You may want to look into the sprak plugs and wires.
Old 11-21-2010, 08:12 AM
hotrodneb's Avatar
2002 CLK
throttle sensor
Old 11-21-2010, 10:28 PM
rediahad's Avatar
magLipVE
i have the exact same problem on mine and i only have 71k but is started at 69k, i thought it was the mas also but now that i see what is going on with yours maybe it isnt
Old 12-08-2010, 05:47 PM
CaliE320's Avatar
88 260 E
it's probably a coil ready to go bad.
Old 12-09-2010, 12:32 PM
bryant9850's Avatar
2002 CLK55
Check your plugs and wires. Make sure plugs aren't fouled, and make sure all wires are secure on the plugs
Also, since everyone is throwing out other options try the crank position sensor. Those go out all the time and can eventually cause your car to not start at all.
Old 12-09-2010, 10:40 PM
dlbehrns's Avatar
99CLK320,
I think he already did that but he called it a cam position sensor. Yes? No?
Old 12-10-2010, 07:23 AM
gregory13lil's Avatar
2000 CLK430
I had an issue after I did a tune-up a while back and after replacing other parts I found 2 small and easy issues that I should have caught.
1. One if the spark plug wires near the firewall was not on all the way. I pushed it all the way in and it smoothed out a bit.
2. After this I rechecked all connections and found that the Maf connector was loose as well.
I guess my point is to make sure you double check all the basics before you go buying other parts. Check all the wires at the plug and coil, check Maf connections, check the vacuum tubes that connect to the valve covers. Ensure that you don't hear and hissing sounds from the plastic vacuum tubes because that means that you have a leak somewhere. I will try and come up with other things later.... Need my morning coffee first!
Greg
Old 12-10-2010, 10:52 AM
2000 CLK430
I thought we actually had both? A Cam Position Sensor and A Crankshaft Position Sensor..... Am I wrong about this?
Old 12-10-2010, 11:46 AM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Crank sensor... well actually flywheel sensor if u want to get technical.
Old 12-10-2010, 12:57 PM
VIPclk320's Avatar
CLK W208
We have a CPS, Crank Position Sensor or like bobbyjo9 said flywheel sensor. very easy fix it costs about $60 in parts and can be done in 10 minutes with a long allen key.
Old 12-12-2010, 01:43 AM
rediahad's Avatar
magLipVE
wouldnt a check engine light come up if those were the issues
Quick Reply: HELP WITH 2002 MERCEDES CLK 430
