MB 325.0 Approved Anticorrosion/antifreeze agents
Old 10-10-2010, 03:51 PM
Xhale707's Avatar
C320 2002
MB 325.0 / 325.3 Approved Anticorrosion/antifreeze agents
Last update: 10/07/2010
I Don't Know if this list will help anyone but i thought i would post it.
Old 10-10-2010, 03:57 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Actually this helps me. Thanks!!!
Old 10-10-2010, 04:13 PM
Star Rider's Avatar
My Ride
So Mobil is the only producer of approved MBZ anti-freeze in the? Interesting.
Old 10-10-2010, 04:20 PM
Xhale707's Avatar
C320 2002
Zerex was another at the very bottom
Old 10-10-2010, 06:17 PM
Super Moderator
Glyn M Ruck's Avatar
Please note that these are not the long life coolants:
You should use products meeting 325.2 or 325.3 or newer
Old 10-10-2010, 07:14 PM
Xhale707's Avatar
C320 2002
Updated
File Type: pdf
File Type: pdf
Old 10-10-2010, 09:02 PM
Super Moderator
That's the stuff bud! I keep meaning to stick all this on my oil thread but you have made it easy to search
Old 10-10-2010, 09:11 PM
LILBENZ230's Avatar
So don't top up with 325.3 if your car currently has 325.0? My 05 book says 325.0 and has a 14y/150k lifespan supposedly.
Old 10-10-2010, 09:28 PM
Super Moderator
Your book has one of the many F---ups that Benz make. 325.0 will never go 14/15 years.
Old 10-10-2010, 09:45 PM
LILBENZ230's Avatar
I suspected as much. No matter. My car would have 400,000 miles @ 15 years old - coolant would be the last to worry about. What's a good interval?
Old 10-10-2010, 09:52 PM
Super Moderator
100K
Old 10-10-2010, 10:02 PM
LILBENZ230's Avatar
My 100k list is growing as it rapidly approaches. I'm about 90 days away from it.
Old 10-10-2010, 10:09 PM
Xhale707's Avatar
C320 2002
What type of list you looking at?? For your 100k?? I just hit mine 2k miles ago...
Trans flush is coming soon
Old 03-04-2018, 12:30 AM
Green Machine's Avatar
2003 C230K Coupe
Hey guys. Coolant check came on this week. 2003 C230 Kompressor Coupe - manual says 325.0 anticorrosion/anti-freeze. I looked up the list of approved on the bevo.mercedes-benz website here: https://bevo.mercedes-benz.com/bevolistenmain.php?navigation_path=bevolisten&lang uage_id=1&blatt=325.0&content_action=show&mark=&su chbegriff=
and I see the Zerex G-48 is an approved coolant.
The Zerex G-48 coolant is blue, mine is currently orange. I did some search and most said colour is not an issue (i.e. I can mix blue with my current orange).
Also, the manual talks about how important it is to use the anticorrosion coolant because of the aluminum parts. But I don't see that the Zerex G-48 says anthing about anti-corrosion. I'm assuming because it's on the MB approved list, it's ok? Just wanted some clarification from other W203 owners.
Thanks in advance guys!
Old 03-04-2018, 01:33 PM
efzauner's Avatar
2005 C240 2011 R350
How do you know the coolant is bad? my 2005 C240 is on 150K Miles clear coolant.
Old 03-04-2018, 05:40 PM
2003 C230K Coupe
Not saying the coolant is bad - it needs to be topped up. Checking on the appropriate coolant to add.
Quick Reply: MB 325.0 Approved Anticorrosion/antifreeze agents
