Turn signal right mirror..
Old 09-08-2010, 05:14 PM
Paculdo's Avatar
06 CTT-S
I'm getting this error and, as it says, signal doesn't work (right mirror).. but sometimes it's on (this error), sometimes it's off.. at most about a week this shows up, then it goes away (and the signal lights DOES work).. right now it's ok.. not sure when this will show up again.. service A is due in 20 days.. would this be covered by MB warranty?
Old 09-08-2010, 06:24 PM
pcy
pcy's Avatar
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Generally speaking, Services A & B are to "check" or "inspect" various components. If any of the component needs repair/replacement, the car owner has to fork over the money for the repair/replacement.
Old 09-09-2010, 12:58 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
not sure if mirror blinkers are covered under warranty...
do u have folding mirrors?
Old 09-09-2010, 07:47 AM
Super Moderator
Glyn M Ruck's Avatar
Sounds like a bad connection at the mirror cover plug. Take off cover & clean. If you need a new repeater they are cheap at RMeuropean
Old 09-09-2010, 08:45 AM
Paculdo's Avatar
06 CTT-S
Not folding.. I thought the blinkers were busted.. but now they are working fine.
Old 09-09-2010, 08:47 AM
Paculdo's Avatar
06 CTT-S
Thanks.. I will check.. now to find a diagram/manual on how to take the cover off and find that repeater..
Old 09-09-2010, 01:50 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Mine had that issue and the assembly was replaced under warranty. It was the exact same stuff you described.
Old 09-09-2010, 06:31 PM
Super Moderator
See here - easy once you give that tough spring a shove.
LED's either work or they don't. They can't be intermittent. Check connections.
https://mbworld.org/forums/showthrea...remove+mirrors
Old 09-09-2010, 09:53 PM
Jimmer's Avatar
2006 C230 SS, 1998 Jeep Grand Cherokee, 1993 Ford F150 Lightning
My 2006 had the same problem. I took it back to the dealer on August 24 and they replaced the lamp (1 203-820-16-21) at no cost under warranty.
Old 09-09-2010, 11:05 PM
Super Moderator
If there is a dry solder joint in the sealed housing then replacement is the answer
Old 09-10-2010, 05:36 AM
phister's Avatar
06 C230 SS 6spd
Mine was doing the same thing awhile back, I just took apart the mirror, cleaned it up and made sure the wires where away from the springs and other parts that could pinch off the wires, works perfectly now.
Old 03-29-2018, 07:34 PM
Jindu's Avatar
C320
This way also may help... open case and clean the connecting part:
https://mbworld.org/forums/c-class-w...20-2005-a.html
Quick Reply: Turn signal right mirror..
