S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Removing the Drivers Side Outside View Mirror - 98 S420
Old 08-25-2010, 07:28 PM
RJN
RJN's Avatar
1998 S420
Does anyone know how to remove the entire Drivers side outside view mirror.
I am blowing fuse #30 whenever I control the mirrors or the steering wheel adjustor. When I use the window switch it doesn't blow. MB dealership said I had a short in the wires (harness) in the outside drivers side mirror.
I want to get to the wires and harness but can't get the mirror cover (shell) off or know how to remove the total mirror from the car.
Anyone know how to do this? Anyone have pictures?
Please help, thank you!
Old 08-25-2010, 10:47 PM
benica's Avatar
1998 and 2002 SL 500, 2014 E550 Convertible
Remove the inside cover...use care when prying it off....small plastic pointed "clips." One at the top and bottom. The cover prys off easily. Once removed...you'll see a piece of foam, unless it was already removed and not reinstalled...remove it and and gently pull the wiring harness until you see the connector...pull it apart...you'll also see 2/3 nuts holding the mirror in place...remove them and the entire mirror can then be removed from the door.
Old 08-26-2010, 12:54 PM
RJN
RJN's Avatar
1998 S420
Thanks Benica, I've been reading many different posts with not much success and this is the 1st one I've read that says that I should go from the inside of the car. All others mention to go behind the mirror from the outside.
Old 08-26-2010, 09:51 PM
benica's Avatar
When you remove the mirror...you'll see 2/3 screw bolts attached to the mirror....they go into the holes in the door and bolts hold the mirror in place. The bolts are permanetly attached to the mirror.
Unless you have a different mirror setup....it can't be removed from the outside. Even the wiring harness has to be disconnected from the inside.
Old 08-27-2010, 11:33 AM
RJN
RJN's Avatar
1998 S420
Thanks. I'm driving a 1998 S420, seems like it might be a different mechanism. Will be trying on Sat. morning and will let you know.
Rate This Thread
Rate This Thread:
Quick Reply: Removing the Drivers Side Outside View Mirror - 98 S420
