Mist Spraying from A/C Vents?
Old 07-04-2010, 09:49 PM
03MBC320's Avatar
2003 C320 4Matic
Hey guys, so its been 100+ degrees and 100% humidity the past week here in Florida, and just a few days ago my A/C started spraying mist at me. I first noticed alot of condensation buildling up around the vents, but just figured it was from the A/C working with all the heat/humidity. This was about 3 days ago. Temp was set to 71 degrees, A/C on, almost at full (1 notch below full blast).
I hit A/C Rest, nothing changed.
I dropped it down to just the fan running (so only 2 bars) and it stopped misting, although condensation was still appearing on the vents
Today on my way back from work, same deal happened. Is this something i should get looked at? or is it just from all the humidity in the air?
thanks guys, just dont want to be stuck down here with no a/c, heats friggin brutal
Old 07-04-2010, 10:18 PM
alpinweiss's Avatar
2005 C230K Sport Sedan, 6 speed manual
Mist coming out of your vents is simply due to the high humidity in Florida (and other Gulf Coast states).
Your air conditioner is cooling the air to below the dew point (temerature at which humidity is 100%), and the result is fog coming out your vents. You can reduce this effect somewhat by putting your air conditioner on the recirculate mode.
There is also the possibility the drain is clogged on your A/C evaporator. This would trap water inside the system, which would then be blown out the vents. To check for this, look under your car and be sure your have a steady drip of water when your A/C is running (on a humid day). If you do not have a puddle of water, your system is not draining.
Old 07-04-2010, 10:38 PM
03MBC320's Avatar
2003 C320 4Matic
^^thanks, i'll check but i think its fine, i had a feeling it was the humidity but this is thefirst summer ive had with the car though so i'd never seen it lol
Old 07-04-2010, 11:18 PM
AdidasC230's Avatar
Saab 900 SE
your car is working fine, being a floridian you should kind of already know this occurs, no "mist" is blowing at you, as said above your a/c is causing condensation to collect around your air vents, its even more obvious at night or if you ride with your a/c on and the windows down.
Old 07-04-2010, 11:32 PM
Infamouz's Avatar
C204, W209, W164
I still think it's poisonous gas.
Old 07-05-2010, 06:11 AM
Super Moderator
Glyn M Ruck's Avatar
Alpinweiss is spot on as usual - Often happen with aircraft aircons sitting on the ground in high humidity at Miami airport & many airports across Asia such as HK, Bankok, Changi in Singapore etc.
Old 07-05-2010, 08:27 AM
03MBC320's Avatar
2003 C320 4Matic
i know, its colorless and odorless too... scary
okay well then i'm gonna go ahead and hi-jack my own thread and ask something i've been wondering
okay my a/c system. A/C Rest button turns the a/c off, making the air warm right? so if i want to heat my car up in the winter, set temp to 80 degrees and hit A/C Rest? or will it blow hot air out with the A/C still 'on'
and whats the blue wheel for the vents do as opposed to the normal ones? i've got a blue one in the center and i cant figure out what it does. At first i thought it was how much cold air came out but opening and closing it doesn't really seem to do much...
god sorry these are such noobish questions, and they could probably be found in the manual lol, but i've read that before and i'm still lost
Quick Reply: Mist Spraying from A/C Vents?
