Suspension squeaking
Old 05-30-2010, 01:37 PM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
Recently Ive been having the infamous squeaking from my rear suspension everytime I go over a bump or even a slight imperfection on the road. Kinda embarassing when you can hear the sound from blocks away
Ive sprayed high temperature, water resistant white grease around/into the bushings and while it reduces the sound a bit, it invariably comes back in a couple of weeks.
I took my car to an indy and he suggested changing the end link bushings on the sway bars and the entire linkage (swaybar to suspension piece) and then troubleshoot further if the noise doesnt go away. What do you guys think of that idea?>
Also, I know a place close by where I can rent a lift and work on the car myself. Are changing these bushings/linkage a diy job? Any DIY's written up?
Thanks guys.
Old 05-30-2010, 02:00 PM
Sathinas's Avatar
His mama. Traded y0 mama in because she was squeaking.
Endlinks shouldn't be that big of a job. Might as well get the whole end link if you have to press the the bushings out of the old one to replace them with new ones.
Old 05-30-2010, 06:05 PM
Super Moderator
Glyn M Ruck's Avatar
PM - TruTaing - He has considerable experience at shutting up squeaky rear suspension.
https://mbworld.org/forums/members/34586-trutaing.html
Old 05-30-2010, 11:25 PM
jcnash's Avatar
Thanks Glyn. Ill PM him and refer him to this thread, so others can benefit later from the information too.
jcnash's Avatar
Agreed. Im at 160,000 km now so the endlinks probably need changing anyway.
Old 05-31-2010, 02:50 AM
Moderator Alumni
TruTaing's Avatar
w203 m112
By experience, Glyn means headaches....
There are only a few items you need to check, but its pretty straight forward for testing.
These are the steps I would take to deal w/ rear suspension noises for the most bang for the buck:
Test Sway bar end links - test these first by spraying them w/ silicone lubricant and driving around. If the sound goes away, replace these. Replacing these end links is kinda difficult because it requires a special MB tool that is a 12 sided star. Maybe someone can post the part number on this tool.
If the sound continues:
Test sway bar bushings - Remove the rear sway bar bushings (actually really easy - its only 4 long screws) and add lots of water resistant silicone grease. Drive around and see if the noises are gone. If the noise disappears you may consider buying new sway bar bushings, but I have found that lots of water resistant silcone grease has done the trick through 2 seasons already.
If the sound continues to presist:
Replace lower control arm (or just the bushings). This is the worste case scenario because you just need more tools to replace the arm OR the bushings. I would suggest just replacing the whole arm (it comes w/ new bushings) because there are actually two on each side that could potentially make noises.
Pretty sure the noise will go away if you check all three of these items.
Good luck.
Old 05-31-2010, 09:01 AM
Super Moderator
That's the spirit
https://mbworld.org/forums/c-class-w...03-thread.html
https://mbworld.org/forums/c-class-w...-happened.html
You will find Rear links, subframe, suspension & wheelbearing, & torsion bar diagrams that I've posted in these threads.
Thanks Tru!!
Old 05-31-2010, 09:22 PM
jcnash's Avatar
Im going to try what TruTaing suggested.
This is such a ridiculously small job...but can be soooo annoying if not fixed.
Any DIY's posted somewhere for the endlink/swaybar bushing replacement?
Thanks guys.
Old 05-31-2010, 10:55 PM
zcurtis00's Avatar
c320 4matic
https://mbworld.org/forums/c-class-w...sway-bars.html
that shows how to change the entire sway bar, so that should help if you have to change the bushing
Quick Reply: Suspension squeaking
