Brake Rotors?
Old 05-06-2010, 11:08 PM
rjlawlor646's Avatar
2001 CLK 320
Brake Rotors?
Doing my brakes soon, already have the pads, need some recommendations on rotors. Drilled? Slotted? Both? I'm looking for something not too expensive either. Thanks
Old 05-06-2010, 11:26 PM
dlbehrns's Avatar
99CLK320,
Go with oem rotors. unless you are running a race car or drive really fast all the time you don't need to worry about heat dissapation or any of that other bs so often hyped by drilled and or slotted manufacturers. they look cool though. ever see drilled or slotted rotors on a nascar ride? you will get pros and cons on both.
Old 05-06-2010, 11:41 PM
xmodrelic's Avatar
2kCLK320
I put brembo drilled in the front and OEM in the back. You are paying for the look more then anything but they look real nice.
Old 05-07-2010, 12:02 AM
2001 CLK 320
also looking for something that wont rust, unless it would make more sense to paint them before installing. I plan on putting wheels on this summer and cant stand the sight of rusty brakes..
Old 05-07-2010, 08:45 AM
Coupecrazy's Avatar
2001 CLK55 AMG
Errr, don't paint rotors...
Unless I mistook your intent.
Old 05-07-2010, 12:16 PM
mint's Avatar
2013 FIAT Abarth 500
Don't get crossdrilled rotors, they're completely useless.
Slotted actually helps with some heat dissipation, moving water from between the caliper and rotor, and keeps the rotor surface slightly cleaner than a plain, flat rotor.
You can't completely prevent rotor rust, but get ones that are zinc plated to help slow down the process momentarily.
Old 05-07-2010, 02:39 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
HAHAHAHH +1 ta that!! I painted mine with high temp BLACK header paint and they look good as the day of install. Remember to clean the rotor surface of any paint before use so you don't gum up the pads
Old 05-07-2010, 02:42 PM
GiZzO's Avatar
CLK55 / E350 Coupe
If you plan on keep your car for a couple more years, definatly look into frozen treated rotors. They come in plain, dimpled and slotted.
http://www.frozenrotors.com/
Old 05-08-2010, 02:30 PM
2001 CLK 320
Has anyone ever heard of or used Bolton Premiere Rotors. There slotted and dimpled for 100 bucks. They are also zinc plated front rotors. This seems pretty cheap and im wondering if i should even bother.
Old 05-08-2010, 02:40 PM
Josh K's Avatar
Tesla Model S
Do they even use the brakes in NASCAR? Aren't the tracks all banked ovals? lol
Old 05-08-2010, 03:41 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
I HAVE HALF SLOTTED HALF DRILLED AND I DEF LOVE IT.. CHANGE YOUR BRAKE LINE TO BRAIDED ONE, BIG DIFFFFFFFFFFFFFFFFFFFFFFF.. TRUST ME ON IT. CAR STOP FAST.
ONLY THING WITH SLOTTED AND DRILLED, CAR WILL VIBRATE WHEN U HIT THE BRAKE AND ITS NORMAL WITH IT.IF U DONT WANT THAT, STICK WITH REGULAR OEM..
I NOTICED WITH MY SLOTTED AND DRILLED, I GOT LESS DUST ON MY RIMS BIG TIME
Old 05-08-2010, 03:52 PM
2001 CLK 320
thanks for all the replies, any good websites i should go through?
Old 05-08-2010, 03:58 PM
FOR ROTOR OR BRAKE LINE?
Old 05-08-2010, 03:59 PM
MY BRAKE LINE GOT EM FROM
http://www.performanceproducts4benz....0&dept_id=5574
2001 CLK 320
Old 05-08-2010, 04:08 PM
AND MY ROTORS FROM
http://brakeperformance.com/site/index.php?ad=direct
Old 05-09-2010, 01:41 AM
2001 CLK 320
thanks..how was the work for the brake line? easy enough diy?
Old 05-09-2010, 08:13 AM
my good friend is a mechanic so he does the work for me and charge me cheap... it was easy but U NEED TO BLEED EM GOOD OTHERWISE U LL HAVE AIR BUBBLE AND CAR WON'T STOP... i remember too him like 20 minut or so for all 4 brakes. its pretty easy as long as u know what u are doing. good luck
Old 05-09-2010, 05:13 PM
GiZzO's Avatar
CLK55 / E350 Coupe
Id be careful of BrakePerformance rotors.
Question thier blanks, as one set from another seems to vary. I would assume from how much they cost, they are lower quality OEM knock offs from who knows where. Then processed; drilled/Slotted/dipped here in the US, so they can justify the "Made in USA" claim.
Atleast we know from Brembo, Baer, Rotora, Powerslot, Frozen are track proven and start off with quality blanks. For safeties sake I would only go with proven brake systems that have a good reputation to keep.
You get what you pay for. Mercedes did a great job with our brake systems why step down for looks? Expect to pay more for looks, not less....
Old 05-09-2010, 05:16 PM
i agree.. there is nothing better than brembo and baer and so forth ... but so for, i got no prob whatsoever.
thank god, maybe im lucky
Quick Reply: Brake Rotors?
