E-Class (W211) 2003-2009
Car Pulling When Braking?!!?
Old 04-22-2010, 07:59 PM
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
So I noticed after I got an alignment, when I press the brakes, it pulls to the left....I googled it and many people say it could be tons of things, so just wondering if anyone else had this problem?
Old 04-23-2010, 01:13 AM
HIRABI's Avatar
K7 GSX-R 750
Take it back to the place you had the Alignment performed at; I'm sure they should be able to correct the issue....
Old 05-02-2010, 06:28 PM
isstay's Avatar
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
Alignment issues.
According to MB, if car pulls to the left or right when breaking at low speed you have worn lower ball joint on that side. Maybe there is been some tolerance keeping the car straight, which is gone after the alignment.
Old 06-10-2010, 08:18 PM
djrabbi's Avatar
Well car still pulls but found out on the left side i need a new ball joint....the mechanic at shell was like i need to get the whole control arm......is this true?
Old 06-11-2010, 08:50 AM
vettdvr's Avatar
03 E500 and Corvette
On some the ball joint is part of the control arm. Newer models the ball joint can be replaced vs the entire arm. Depending on your model there may be a new arm for yours with the replacable joint, so check when buying part.s
Old 06-11-2010, 08:53 AM
djrabbi's Avatar
I have a 03 E500
Old 06-12-2010, 05:55 PM
isstay's Avatar
if is the control arm ball joint you can replace only the joint, if is the torsion arm ball joint you will have to replace the arm because the ball joint is part of the cast.
Old 07-25-2011, 11:16 AM
djrabbi's Avatar
hopefully i get this fixed this week!
Quick Reply: Car Pulling When Braking?!!?
