c300 install rear view camera issue
Old 04-12-2010, 11:22 PM
billvip's Avatar
2018-G550
my c is 2010 model with every package except the back camera.
i was thinking install it by myself. i'v heard the car already preset the video cable in somewhere in the trunk(passenger side). you just plug and play.
is that true?
if so please help me find it out
my english sukx, sorry~
Old 04-13-2010, 11:34 AM
white46's Avatar
08 C300
i'm also from Edmonton, and installed the back up camera myself.
If you want, pm me, i can give you some heads up.
Old 04-13-2010, 01:25 PM
jctevere's Avatar
2012 C250 Coupe
Your english isn't that bad at all, I easily understood you. While I am not familiar with 2010 c class or if the c-class in Canada differs from the ones in the U.S. I know that in my 2009 c300, it did not have a cable in the trunk to connect the back-up camera to. But it has the jack on the radio or command interface to connect to cable for a back-up camera. If you install the back-up camera and run the cable to the command interface, all you need to do is enable the option in the car diagnostics for a back-up camera to let the vehicle know that one is installed.
If however the cable is already run like you said, then all you do is mount the camera under the trunk above the license plate. There is already a great DIY in the sticky thread to show you how to do that. And then just connect the jack to the pre-run cable. After that, if it still does not work, you may have to enable the back-up camera option in the command interface yourself, or by going to the dealer and having them do it.
To do it by yourself (at least on U.S. cars) you must have the key in the ignition but only turned to the right once (electrical but no engine running) after that you press and hold the (Answer telephone button and the "OK" button on the steering wheel at the same time and hold for about 3 seconds)
Hopefully all goes well...
Old 04-14-2010, 06:04 AM
Jae Duk's Avatar
'09 C63
https://mbworld.org/forums/c-class-w...d-cyclops.html
If you search "cyclops" in this forum you will get more results as well. Dunno if those threads will answer your questions though.
Old 04-14-2010, 06:09 AM
billvip's Avatar
2018-G550
the message is confirmed. the 2010 c class DO preset up the video cables in the trunk, but i dont know which one is???
Old 04-25-2010, 12:18 PM
clkcadet's Avatar
S550
Can I enable the cyclops camera even if I have the standard screen? I also saw Midcity had a very cool backup sensor that installs on top of the rear seat (just like the s550) I was wondering if anyone installed that?
Old 04-25-2010, 07:51 PM
HOTGQ161's Avatar
C300 SPORT 4MATIC SEDAN
so is there? in the trunk?
Old 04-26-2010, 01:22 PM
kaku's Avatar
2009 C300S 6mt
are you sure?
where is this cable located exactly?
Old 04-26-2010, 01:47 PM
billvip's Avatar
2018-G550
you have to remove the trunk cover, passenger side.
right behind the "big black box with lots of wires". hope that help
Old 04-27-2010, 07:58 PM
Rogwp's Avatar
2010 C300 4matic Special Edition
Rear camera in 2010 C300 (Canada)
So how is the installation going? Could you post a picture of the cable in the trunk (so that I know what to look for)? I had a rummage in that area but could not find it, however, I did not remove the cover. How do you remove that side cover anyway? Thanks for any help, Roger
Old 04-27-2010, 08:30 PM
billvip's Avatar
2018-G550
i havent done that yet, but i have the pic.
here is the pic, hope that helps.
Attached Thumbnails c300 install rear view camera issue-20100129_632a879918de87221921zfgqzftfftgu.jpg
Old 05-02-2010, 04:42 PM
Rogwp's Avatar
Hi again, I just went to check in my trunk, passenger side, and I can't tell where the photo is taken from. Is it between the fuse box and the back seats, or between the fuse box and the tail lights? Do I need to take off the whole side panel inside the trunk, or should I be able to find the cable through the fuse box access panel? Many thanks.
Old 05-11-2010, 04:54 PM
HOTGQ161's Avatar
my dealer asked me for $1500.....crazy dudes. today i just got the fakra cable from midcity..... so i guess all i need is to pick up a camera, run the cable from the trunk to the nav and plug it in.... is it this easy? i think i also gonna need some sore of programing, is that right?
Old 05-11-2010, 11:03 PM
Rogwp's Avatar
Do you have a 2010? If so the video cable is already in the trunk.
Old 05-12-2010, 11:15 AM
HOTGQ161's Avatar
yeah, 2010 c300 w/ MM..... i heard of this but i cant find it.... i removed the pannals in the trunk and did a light search next to the black box and nothing..... can u tell me wherein the trunk? thanks do
Old 05-12-2010, 11:16 AM
HOTGQ161's Avatar
did u find it in urs?
Old 05-12-2010, 12:12 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
I would search on the trunk lid if it was pre-run at the factory. Thats where the camera will be mounted.
Old 05-12-2010, 01:53 PM
HOTGQ161's Avatar
Just did that and is not there.... ;-( my trunk looks naked.... cant find anything like it, not on the trunk lid, right pannel nor the left one,,,,, i even check the floor. same result. im starting to think this "pre-wired cable" stuff is just a mith
Old 05-12-2010, 08:05 PM
Rogwp's Avatar
Oh, well!
I was afraid of that, I haven't had a good look myself yet, I was hoping that someone else would confirm that the cable was there. The OP posted a photo but I couldn't match the photo with my trunk. My C300 was made 01/10 if that makes any difference.
Old 05-13-2010, 05:42 AM
PREMIUM SPONSOR
rob13572468's Avatar
ML350, Lotus Elise
I have not seen any W204's with the camera pre-wired... The Blue fakra in the pic looks like a GPS or SAT antenna.. The camera FAKRA should be green.
Old 05-13-2010, 03:59 PM
HOTGQ161's Avatar
i think we have been fooled, we want to believe is there but is not, a tech from MB whos a friend of a friend told me "IS NOT"
Old 06-16-2010, 02:50 AM
huir's Avatar
2010 W204
Is there any update for this thread?
Anyone with 2010 C class find a pre-wired in the trunk?
Old 08-29-2010, 09:57 AM
jsturdi's Avatar
Mercedes c 300 2010
C300 navigation wiring in trunk?
Anyone have an update to this thread? Would like to add a camera to my 2010 with NAV. Tnx
Old 04-12-2011, 06:34 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera. 2002 QX4
I also want to know if my 2011 C300 is camera pre wired. Mine has P1 and MM package. I asked three local dealers, some never replied, some said they don't not provide installation. No one says it's pre wired or not.
Old 04-12-2011, 08:59 PM
Garry1104's Avatar
C300 4MATIC
It's really not that hard to do. Took me a good 3 hrs last weekend to do it. All I bought was a FARKA cable from mid-city and a Sony rear view camera from amazon. Total cost was just $111 but knowing I did everything myself and it worked following the DIY info on this forum was just PRICELESS
Quick Reply: c300 install rear view camera issue
