View Poll Results: Is this funky for a Mercedes to be blowing window regulators and door handles
YES
2
100.00%
No
0
0%
Voters: 2. You may not vote on this poll
Right rear door inside handle will not open door
Old 04-04-2010, 10:17 PM
Turboper4mer's Avatar
2001 E320
I replaced the right rear door window regulator and it works fine! but now the door will not open from inside, central locking and unlocking is working but the inside door open handle does not open the door. Outside handle works fine!
I can hear the mechanism when the pul handle is moved but the door latch does not release, I tested it by pushing the door latch and pulling the door handle from inside, NOTHING, but if you pull from the outside the latch releases fine.
Any help will be appreciated!
Old 04-04-2010, 10:46 PM
Fabio D's Avatar
210 55
check if you putting on the children security lock. Maybe are in locked position & only open by the outside
Fabio Daniel
Old 04-05-2010, 12:25 AM
mike430sport's Avatar
2000 E430 Sport
The same thing happened with me on the same door. Soon the door will get stuck shut. The door locking mechanism goes bad and you have to change it. I bought one used from Ebay for $50. I installed it myself now door opens and closes perfectly. My door was locked shut for months till I got around to do it. It is pretty easy to do. Just follow the steps here You don't have to mess with the acuator cause the used one will have it already. Just R&R the old for the new.
http://www.benzworld.org/forums/w210...ml#post3603953
Old 04-05-2010, 12:59 AM
raymond g-'s Avatar
99 E320
turbop-
since this coincided with your repair of the window reg, i'll put $10 on the
root cause being the cable having come loose from the inside door handle.
fortunately, as you already know how easy it is to remove the door panel,
you can just take a look and verify that this is the case or not.
if the outside door handle functions normally,
the smartkey un/locks normally,
the console swich un/locks normally,
the manual door lock pull functions normally,
.....and the only problem being he inside square door handle fails to
manipulate the door latch and releasing it to open....
it sounds like the cable to me. the cable terminates to a semi-circle fixture
which should slip into the door handle. i seem to recall that there is also
a plastic fitting that pivots to prevent the cable from popping out of the
door handle easily.
if this is the case, the repair will take less than 5 mins.
Old 04-05-2010, 12:15 PM
2000 E430 Sport
Old 04-05-2010, 03:17 PM
raymond g-'s Avatar
99 E320
great. thanks, mike. i think that "190" is the nylon latch which covers the elbow at the
end of the rod "200" {fading memory}
Old 01-27-2015, 11:49 AM
81 Benzo's Avatar
81 300SD, 98 E320 Wagon
I've got the same issue, took off panel to fix window track, and now the inside door latch mechanism is stuck forward so the cable is too slack to open door from the inside. Pulling on the cable manually does not release latch. Outside handle and lock both work fine.
There is a perfect specimen at the local "U-pull it" to get a replacement. However before I pull that trigger, has anyone been able to fix the latch without replacing?
Tab indicated with blue arrow should be in position indicated with purple
Old 02-03-2015, 07:44 PM
81 Benzo's Avatar
Ok everyone, save your $ on buying new mechanism.
Low quality video of me fixing my old one after buying an intact one at a U-pull-it and comparing the two.
This thread is probably dead, but for those who have this issue, who knows what google can find these days...
Quick Reply: Right rear door inside handle will not open door
