R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
R-Class Air Filter Change
Old 03-12-2010, 06:24 PM
memli's Avatar
Mercedes R 320 CDI Sport 4Matic
I bought a pair of air filters for my R-Class and was very disappointed to discover that I have to remove the top cover of the engine to access the filters. Its very tight and I'm not able to remove both top covers as there is very little space.
Need some help...
Thank you in advance
Old 03-12-2010, 09:05 PM
valmomo69's Avatar
R350
Hope this helps !!
Old 03-13-2010, 07:57 AM
memli's Avatar
Originally Posted by valmomo69
Hope this helps !!
Thank you, but the 320 cdi air filter compartments are on both sides of the engine not same as R500 on top.
Old 03-13-2010, 07:19 PM
Mort's Avatar
Follow the steps in the PDF file in the post above. Worked for me on our 08 R320 CDI. It is not identical but after step 5 you should be able to work the rest out yourself. The big deal is getting the cross brace out so that you have room to work. The whole intake tubing and filters lift out as a unit after you remove a couple of screws on each side that hold the filter boxes down. Take your time and have a good look around and you can do it.
The only advice I had was to remove the cross brace and I figured out how to do that and did the rest by myself without any other help.
Good luck.
Old 03-14-2010, 10:32 AM
memli's Avatar
I have done it after finding this video that helped me a lot.
http://gallery.me.com/fmoffa#100036
Old 04-02-2010, 10:16 PM
boots21's Avatar
R500
God Bless you my friend!
Old 04-03-2010, 06:49 PM
memli's Avatar
I hope you found the video usefull...
Old 07-02-2010, 07:19 PM
jbhatia817's Avatar
2006 Mercedes R350
Thank you very much, it helped me out a lot
Old 07-05-2010, 11:20 AM
bmo72's Avatar
C240 and R350
Great stuff! Thank you.
Old 07-07-2010, 07:51 PM
smokersteve's Avatar
06 R360, 06 F350 6.0, 04 CayenneS, 96 911TT 500HP, 86 928S, 74 911S, 73 914-4, 70 914-6, 02 Durrango
thanks for the links!
Old 07-13-2010, 09:31 PM
sn8k's Avatar
2008 R350
Thanks for the post...I just ordered two K&N's and was wondering how to replace OEM filters.
Old 07-14-2010, 02:57 PM
lkchris's Avatar
'07 GL320CDI, '10 CL550
Disappointed?
Here's the thing about German cars: not a design nanosecond was devoted to making DIY easy.
Quick Reply: R-Class Air Filter Change
