Diesel Forum Forum for Diesel engine vehicle related discussion
05' E320CDI Where is the EGR Valve?
Old 01-27-2010, 05:03 PM
5714ss's Avatar
E320 CDI
Smile 05' E320CDI Where is the EGR Valve?
I beliveve I have a bad EGR Valve or it needs to be cleaned out. Th ecar has over 200000 miles on it and althought it runs fine most of the time, lately it is going into " limp mode" Does anyone where the egr valve is so I can clean or replace. Pictures are helpful
Old 01-28-2010, 03:22 PM
TMAllison's Avatar
09' E320
First step is to scan it with an OBDII scanner and find out what code its tripping.
Old 01-30-2010, 01:11 PM
MBtech1098's Avatar
10 speed bicycle
It is in the back of the engine near the intake...but as TM said, I would check DTC's before I just stared ripping into stuff.
Old 03-08-2012, 10:06 PM
algeria's Avatar
2005 E320 CDI 1985 300 CD Turbodiesel 2021 GLC300 4matic
2005 CDI EGR problems
Hi My EGR carboned up on my car (E320 CDI 2005)and I lost power on and off. No codes came up. I googled the trouble and they said try cleaning the EGR I was on vacation and with the tools I had in my trunk I was able to clean the carbon out of it . It is on the back of the intake manifold it is controled by a motor. It carboned up again after a few thousand miles so I ended up replacing it at about $400. I didn't upgrade the software just changed to EGR and had no problems after 10,000 miles.
Old 03-09-2012, 09:33 AM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 OM642 ; R107 M117, Sierra 1500 LZ0
Any idea about the bluetec version? Is this a problem, can it also be easily cleaned?
Old 03-09-2012, 08:39 PM
algeria's Avatar
Carboned EGR
Hi I don't know about the blue tec engine but my experience with EGR valves is they all carbon up and I've had 5 Mercedes diesels. They are easy to clean, remove 2 screws and disconnect the wire, pull it out spray some brake cleaner on it and lubricate the motor shaft with high temp lubrication. I've reused the gasket. I was in bumper to bumper traffic when it first happen and the car showed no codes on the dash not even a check engine light. The car had no power. I babyed the car to my destination and googled the trouble and had it fixed in about a half hour. It carboned up again and not wanting to get stranded in a place I couldn't fix it I just replaced it myself. Saves the trouble of cleaning it every year or so. The replacement EGR has a different design so maybe it will last longer. Hope this helps Al
Old 03-11-2012, 02:18 PM
lkchris's Avatar
'07 GL320CDI, '10 CL550
Bluetec versions should be better simply because the 2005s in question ran two years before ultra low sulphur diesel was available.
Old 03-11-2012, 06:47 PM
algeria's Avatar
EGR problem
Hi Well I hope that the ultra low sulphur diesel is the cure. I'll let yous know if the replacement EGR carbons up as I replaced it last year . I know it will be the first place I will look if I get the loss of power issue again. Thanks Al
Old 03-16-2012, 09:55 PM
Whargoul's Avatar
1985 300DT
It is not. The EGR plugs up from the combination of exhaust soot and crankcase vent oil vapors returned to the intake.
The only two ways to prevent EGR buildup are to disable the EGR or reroute the CCV system so it vents to the atmosphere instead of the intake.
Old 03-18-2012, 05:59 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Are there any disadvantages in disabling the ERG in the modern diesel engine ? Does it increase exhaust gas temps or upset the engine management system?
Old 04-03-2012, 06:52 PM
Whargoul's Avatar
1985 300DT
There is no advantage to using an EGR system on any engine, its purely and emissions control device.
Old 03-20-2017, 06:37 PM
benzE3202000's Avatar
Mercedes E320 Y2000
Should one clean the EGR valve as a routine maintenance. I have a 2006 E320 CDI with 206K miles. Still driving great.
Old 03-31-2017, 03:20 AM
Airton123's Avatar
w211
Better choice to add emulator and dont waiste time and money for egr system.
http://ces24.com/home/10-mercedes-egr-emulator.html
Job done, works fine.
Quick Reply: 05' E320CDI Where is the EGR Valve?
