Passenger side mirror acting up - no dip down
Old 01-06-2010, 05:18 PM
j-mo's Avatar
2006 E55 AMG, 2002 CLK55 AMG, 1969 Mach 1 Mustang
Greetings-
I recently noticed my passenger side mirror is no longer tilting down when I put the car in reverse. I am able to adjust it just fine on my own. Any idea why?
Is it starting to go?
Thanks!
Old 01-06-2010, 07:40 PM
gregory13lil's Avatar
2000 CLK430
The tilt-down feature will only work if the mirror selection switch is set to the right side mirror. Is it set to the right already?
Greg
Old 01-07-2010, 04:03 AM
DBLNICKL's Avatar
CLK 55
i believe the feature is thrown off if the batt. is disconnected as well...w209's have an option in the cluster to reset it...i dont see why the 208 wouldnt as well...
Old 01-07-2010, 09:55 AM
hami's Avatar
CLK55 '05 CLK320 '02
Greg
The best thing to do is to be sure the mirror switch is set to the right and the gear in reverse. If nothing moves u must move the mirror to the position you would like it to move to while keeping the car on reverse gear. At this point when you change the gear the mirror will adjust itself and will return to the same position it was at before reversing and it will also return to the position you just selected when ever you reverse. If that doesn't work then you might have a fuse problem.
Old 01-09-2010, 09:36 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Originally Posted by j-mo
Greetings-
Thanks!
Wow nice! I did not even know that CLK55's had that feature. The C43's don't. I wonder if it could be added.
Old 01-09-2010, 10:19 AM
kevblah's Avatar
E90 M3
ive tried everything to get this feature to work on my clk550, but it won't work...any thoughts?
Old 01-10-2010, 04:49 AM
hami's Avatar
Have you tried what I have wrote above?
Old 01-10-2010, 02:26 PM
kevblah's Avatar
E90 M3
yeah i tried it, didnt work.
Old 01-10-2010, 08:08 PM
2000 CLK430
You are absolutely correct. I had disconnected my battery and the feature would no longer work until I placed the car in reverse and set the mirror to the correct tilt down and then I placed the car in drive. As soon as I went to drive the mirror went back to normal position. When I placed the car in reverse again it finally went to the tilt down position I had set minutes earlier. So, for those that are trying to get the feature fixed this is a MUST DO.
Greg
Old 01-11-2010, 05:11 PM
DBLNICKL's Avatar
CLK 55
did u go into the instrument cluster/options and turn the feature ON? i'm guessing if u go thru the motions of setting it, it's still not gonna work if the feature is actually turned off...
Old 01-12-2010, 02:14 AM
GiZzO's Avatar
CLK55 / E350 Coupe
I have a problem after it tilts in reverse it doesn;t fully return to normal position. I sometimes have to hit one of the seat memory to get it back.
Old 01-13-2010, 09:08 AM
darkside7's Avatar
clk 430
thats the same issue I have with my mirror. I have already replaced the window switch. Any thoughts????
Old 01-13-2010, 11:17 AM
j-mo's Avatar
Mine ended up being the switch selector set on the left. I just changed my battery and had to re-sync the seats etc. I re-adjusted the mirrors and kept it on the left. After selecting the right button it started working right away.
Thanks for the tip!
Old 01-16-2010, 01:02 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
I had that happen on my 210 and one of the hall sensors in the mirror motor was faulty. I ended up replacing the mirror motor to remedy it.
Nick
Quick Reply: Passenger side mirror acting up - no dip down
