CL-Class (W215) 2000-2006: CL 500, CL 600
fuse diagram for 2000 to 2002 cl500 "help"
Old 12-18-2009, 04:07 PM
johnbarbados's Avatar
2001 mercedes cl55
does anybody have a fuse diagram for a 2000 to 2002 cl500 to cl55.
my car is completley draining my battery ive already replaced the alternator and battery. i just talked to my mech and he said it might be fuse box link or a k40 relay but failed / refused to tell where they might be located so any help will be greatly appreciated
Old 01-03-2010, 07:19 AM
gnati2005's Avatar
e-class w211, vito
my car is the same problem, i try to find what is the problem.
Old 01-03-2010, 08:19 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
There are 2 fuse boxes in the engine compartment, 1 on each side. There is another directly under the front of the right rear seat behind the panel (carpeted). At a minimum you should get the owners manual for your car to help you with such stuff and ideally get the Star Service Manual Library for the 215/220 models. You can order this from MB at their USA main office by calling 1-800 for-merc. Lastly, I would not ever deal with a mechanic that refused to give you help, especially as simple as this, as it's obvious his only concern is $. Good luck.
Old 01-31-2010, 02:54 AM
kataboboi's Avatar
Mercedes
has anyone already order yet.... ???
Old 01-31-2010, 02:55 AM
kataboboi's Avatar
Mercedes
I got the same problem..
Old 01-31-2010, 11:35 AM
ch33sehead's Avatar
2005 CL65 (current), 2001 CL600 (chopped)
Any good mechanic/electrician with a voltmeter should be able to test all of your relays and figure out which one is forced closed and doing the draining.
Old 04-26-2010, 01:16 PM
gnati2005's Avatar
e-class w211, vito
Hi your car fixed ?
Quick Reply: fuse diagram for 2000 to 2002 cl500 "help"
