HID Relay Harness Problem
Old 12-06-2009, 05:59 PM
yeloaw's Avatar
c240
I have searched the forum but cannot find an answer to my problem.
Currently I have aftermarket HID installed on my car with no problems except for occasional flickering upon starting the car.
To solve this flickering I decided to install a relay harness to draw power directly from the battery.
I installed the relay harness but the relay seems to trigger an inconsistent flow of power from my battery to the ballast. I cannot figure out what the problem is??? Pos/ground connections have all been dbl checked and are correct.
Please view the problem here.
My car is a 2002 c240. Anyone with a prefacelift 203 successfully install a relay harness?
Does anyone know why or how I can fix this??
Old 12-06-2009, 08:37 PM
e1000's Avatar
a quarter mile at a time
Are you getting errors?
Old 12-06-2009, 09:06 PM
HellsAngel's Avatar
03 c320 coupe
i dont know if we are talking about the same problem, but when i first installed my xenons the lights used to flicker when they were not on...
i did now know about the set xenon=present thing... so i fiddled with the on board computer, i dont remember what exactly, but there was an "thing" in the lighting submenu that you can set to "continuous / alternative".... i set it to alternative or something like that... and it solved the problem.. now its working perfectly altaught i did not set xenon to present !!!!!!!
Old 12-07-2009, 12:04 AM
Super Moderator
samaritrey's Avatar
THE C350
ok you changed the setting that has your headlights always on or manual mode in the ic. when in manual mode you can use the headlight switch to auto or off or on or whatever you want.
Old 12-07-2009, 12:23 AM
acr2001's Avatar
2012 C300 4Matic
Yes, but it should be noted that when the headlights are set to continuous (DRL mode) the lights will be getting LESS THAN 12 Volts during the day time and 12 Volts when the ambient light sensor detects that it's getting dark out / night time.
This is because the headlights are dimmer during they day in DRL mode. I imagine this is not good for your HIDs!!
Old 12-07-2009, 12:27 AM
Super Moderator
samaritrey's Avatar
THE C350
don't think that is true for USA cars.
Old 12-07-2009, 12:35 AM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
It is true for my lights. I don't know why, because I know that others don't have that.
Old 12-07-2009, 12:37 AM
yeloaw's Avatar
c240
Yes I get errors when the lights flicker. Errors say left or right headlamp needs to be checked.
Old 12-07-2009, 12:40 AM
Super Moderator
samaritrey's Avatar
THE C350
turn the lights on with the key out of the ignition what happens?
Old 12-07-2009, 12:48 AM
yeloaw's Avatar
c240
Same thing happens
Old 12-07-2009, 01:06 AM
Super Moderator
samaritrey's Avatar
THE C350
Same thing happens
interesting then i would say bad connection or ballast or something. the car does not regulate power until you turn it on. when i put in my bix i used that so that they would work until i got the setting changed. turn the lights on wait 20 seconds then start car no error.
Old 12-07-2009, 01:43 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
check all your grounds...it looks like a bad ground or bad ballasts. I'm would say its more on the side of a bad ground somewhere. Make sure you have the ground connected to the battery as well. Also make sure you didn't cross the grounds and pos some where.
This is a video of my s2000 hid projector retro with quick start up of my xentrac ballasts on philips 4200k bulbs. I have a relay harness directly connected to the battery and i used the side marker as the trigger.
http://www.youtube.com/watch?v=mNidKl4kHME
Old 12-07-2009, 02:02 AM
e1000's Avatar
If you are using a relay, then it's because the relay isn't using any electricity. Once the car sees that no electricity is used, it will cut all power, thereby turning off the relay. This happens over and over again, and that's why you're getting the flickering. You'll need a resistor on the car side of the wiring harness so the computer will think there is a bulb present.
Old 12-07-2009, 02:05 AM
acr2001's Avatar
2012 C300 4Matic
It is indeed true. I can speak for the USA spec 05 C class anyway.
Old 12-07-2009, 02:19 AM
TemjinX2's Avatar
if your using a low beam wire as the trigger, just use the side marker wire instead. I recommend against using resistors since they get really hot.
Old 12-07-2009, 05:10 PM
Super Moderator
samaritrey's Avatar
THE C350
ok must have been changed. i would have noticed them being dimmer during the day then at night. all Canadian cars though have drl i know that.
Old 12-07-2009, 11:46 PM
bdgdl08's Avatar
I really don't know what the deal on that is. Matt's do not run dimmer during the day, but other '05s do. So who knows.
Old 12-08-2009, 02:23 AM
acr2001's Avatar
2012 C300 4Matic
Something is weird about this. I can tell you that they are functioning on my car as they did from the factory (no modifications).
Probably a 05+ thing.
I would never have realized that they were dimmer during the day had I not been shining the lights on a shady wall when I switched from AUTO to the headlight symbol. After that I did it a few times to see if I was crazy, but it's a pretty big difference.
Old 12-08-2009, 01:05 PM
bdgdl08's Avatar
I only realized it because I was doing the same with my reflection in the back of cars in front of me. I did it multiple times to check that I wasn't imagining things... black cars (SUVs to be specific) work as very good mirrors
Old 12-08-2009, 01:16 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Drew is right, and hate to throw a wrench into your thing ACR.. but my car's lights run at full power AND run all outside lights when I set Headlamps = Constant in the IC. I've seen 2007 cars running their low-beams on lower-power during the day and no exterior lights.
My car is just special, I guess.
Old 12-08-2009, 03:41 PM
acr2001's Avatar
2012 C300 4Matic
I remember discussing this in another thread with you... I don't understand what Mercedes was thinking with this weird behavior between cars. My marker lights DON'T turn on when the headlights are dim during the day and the manual even mentions this specifically (that the marker lights will not turn on until dusk if you are in auto mode with headlamps set to constant.
Old 12-08-2009, 03:56 PM
LILBENZ230's Avatar
My car is weird, anyway. I have a HID kit that gave me no errors, ever. But it hasn't worked for others with 2005 C230s. It's also accepted that if you have a HID kit, you cannot set your headlights to "constant" or they will flicker. Not on my car, but I guess that's because my car just runs all lights at full power in that scenario.
Quick Reply: HID Relay Harness Problem
