No reverse - transmission problem
Rating: Thread Rating: 5 votes, 5.00 average.
Old 11-18-2009, 10:58 PM
mbnz's Avatar
1990 300E
My car all of a sudden doesn't want to go into reverse. That is what I found out after driving it for an hour. And 1/2 hour later, started it up and it wouldn't go into reverse.
I noticed that when I first start it up it goes into reverse no problem. But if I drive for say 20 minutes, it won't go into reverse unless I rev it up to about 1500K.
The rest of the transmission is fine. It shift good and smoothly. I got about 240K. I always did the transmission fluid changes on time.
SO I went to a transmission shop, and they said maybe the seal. They say you have to open it up, and while you do that you should do a complete overhaul and change the torque converter. The cost $2700 !!! And if it need other parts, like gears then extra.
So any recommendations. As funds are tight now, I would rather just fix the reverse problem. I just don't think it is worth paying $3000+ for a complete overhaul.
What should a reverse fix only problem cost? How many hours - I assume it is just a seal or piston that has gone bad.
Any suggestions? Anyone know a good transmission shop in Greater Vancouver that will do it for a good price?
thanks.
Old 11-19-2009, 12:24 AM
190E 16V's Avatar
1987 560SL
thanks.
The tranny in my car has a failing reverse - all the rest is great. My MB mechanic, Bernie at MB Euromotors (604-874-0744), says he has guy who does an excellent job at rebuilding these trannys. Approx cost: $2500 - not sure if that includes the re & re.
Apparently, it is not possible/very unadvisable, to just repair Reverse. Better to rebuild entirely. I have heard this from several sources.
Whatever you do, don't buy a dealer MB Rebuilt tranny.
I think you should stay with an MB specialist. However, you could try Bert's on Kingsway, if they are still there.
Do NOT go to Alltrans on Kingsway. I went there a few years ago and the guy was a classic ripoff artist - absolutely disgraceful, no conscience, no ethics.
Good luck NZ
Old 11-19-2009, 06:40 AM
Pottering's Avatar
Formerly a 1987 190E, now a 1994 E320 Coupe
Times for R&I and overhaul
Let me know what transmission you have, ie 722.369, and I have a document that gives removal and installation times plus overhaul times. On average it's about 7 hours for R&I and 12 hours for overhaul, so use that to get started on an approximate cost.
Old 11-19-2009, 09:42 AM
ps2cho's Avatar
E
These transmissions rarely have any mechanical problems. The only wear items are the friction disks and seals. If you are up for a tranny removal yourself, there is a recent thread I made over @ peachparts if you search my name.
Its about a 2-4hour job based on experience for removal and about the same time to put it back in. Not difficult, just awkward it seems. I gotta pull mine to do the front pump seal that is leaking.
Old 11-20-2009, 04:52 AM
mbnz's Avatar
1990 300E
I'm not sure what transmission I got 722.xxxx
I have an automatic, 1990 300E 3.0L 2WD
It is re-assuring to know that the transmissions rarely fail. I think it is just the one thing that needs to be replaced. Probably just the seal. I'm going to look for a place that knows MBs and will do it for under $800-900 tops.
I'm not sure if I have a 722.3-722.4 tranny or not,
but this link shows the common causes of reverse problems for these transmissions.
http://europeantransmissions.com/Bul...erctechlib.htm (click on 722.3 slipping or no reverse)
thanks guys, ps2cho I'll look at your posts, but that repair is way beyond my mechanical abilities.
Old 11-20-2009, 05:48 AM
Pottering's Avatar
[QUOTE=mbnz;3817522]I'm not sure what transmission I got 722.xxxx
I have an automatic, 1990 300E 3.0L 2WD/QUOTE]
Use the Russian Vin decoder to see what version of transmission you have.
http://old.mbclub.ru/mb/vin/?lng=eng
Old 11-20-2009, 04:10 PM
mbnz's Avatar
1990 300E
From MB dealer: I got 722.358 xx xxxxxx
Exact same number from Russian site. That is a good resource !!!
Old 11-20-2009, 07:27 PM
Bigpete123's Avatar
1990 300ce
I'm no mechanic, but over the years I've seen many posts just like this: reverse stops working first. It happened to me as well.
I called many shops and they all told me the same thing your mechanic did. I know money is tight, but you really need to think about how much longer you want to drive the car. If you want to keep it for a while, at your mileage, you probably need a full rebuild.
Old 11-21-2009, 05:04 AM
mbnz's Avatar
1990 300E
Sorry, I didn't make my mileage on my car clear. I forgot some of us are thinking miles and others kilometres.
My car
1990 300E (3.0L) transmission is 722.358
Mileage is 155,000 Miles (about 248,000 kms). So in my earlier post I put 240K (that is km) - sorry I should've been more clear.
So there is a big difference between 240,000 Miles vs 240,000 Kilometres.
That being said, what is the typical mileage the transmission on this car goes? (specify km or miles) - I'm talking about gear slipping etc, problems requiring a full rebuilt (assuming regular maintenace is done)?
Old 11-21-2009, 07:40 AM
Pottering's Avatar
722.358
Should be 6.9 hours removal and installation of transmission from vehicle
chassis and 12.3 hours bench overhaul time for transmission.
http://www.autoshoppingcenter.com/tr...umbers124.html
http://northridge-california.olx.com...58-iid-3378203
http://www.mercedesnewparts.com/Rend...@@300e&mode=PA
Old 11-23-2009, 02:40 PM
Bigpete123's Avatar
1990 300ce
My tranny went out at 185k miles or so, with the same symptoms as yours.
Old 11-28-2009, 05:05 AM
mbnz's Avatar
1990 300E
Bigpete, did you mean just the reverse went out or the whole tranny?
Old 11-29-2009, 01:12 PM
CharlestonN's Avatar
03' CL55 AMG
my reverse went out at around 217k miles I am now at just under 150k miles
I was. quoted $2200 for complete rebuild and $1100 for just the reverse, the comlete rebuild comes with a 100k mile warranty
Old 11-29-2009, 04:43 PM
mbnz's Avatar
1990 300E
Did you mean you are just under 250K miles now?
So I take it you haven't got it done yet?
100K mile warranty is unreal, I never heard anyone hear in Vancouver offering anything like that. MB won't even, they only offer 2 years warranty - not sure if there is a mileage limit too.
Old 11-29-2009, 11:23 PM
03' CL55 AMG
No, i haven't had it done yet, i am going to buy a 04/05 SL55 around the beginning of the year so i will most likely garage my W124 and slowly restore it, i already ordered my new wheels for it, they should be here thursday
Anyway, i just try not to park in any spot that is not angled down or at least level until i have it fixed
As long as the car is fairly cool the reverse works well enough
Old 11-30-2009, 05:01 PM
Bigpete123's Avatar
1990 300ce
Just the reverse went out. I never let it get to the point where the whole thing was shot.
My advice is just based on what multiple shops told me independently... I was told that a bad reverse is the first symptom of the whole thing needing a rebuild. They told me it'd be nearly the same amount of labor to fix the reverse vs a full rebuild. They said at my mileage, I could have them pull the tranny, fix the reverse, and have the rest of the tranny go 10-20k miles later.
So I guess it's just up to you do to decide whether you want to take that risk... Just doing the reverse now may save you $500 in the short term, but if they have to take the whole tranny out to do a full rebuild a short time later, the first "half rebuild" is money down the drain.
Old 11-30-2009, 09:30 PM
mbnz's Avatar
1990 300E
You are right, they opened up my tranny and the rest of it is showing signs of it failing. It will be only a matter of time before it goes.
You are right, it makes sense to do a full rebuild if you are keeping the car, which I am planning to do.
I am getting the overhaul done.
Old 12-13-2009, 01:53 AM
hchau5's Avatar
1993 Mercedes 400E V8 4.2L
RE: Transmission
I have the same problem. No reverse and found it out the transmission was bad. I drive a 1993 MB 400E. My friend has a 300e and had the same problem and got it fixed. He recommended me a website where he got his transmission. I bought it rebuilt and sent them my old one for under 1300. Still driving today after 5 years of fixing it. Also, the company offers some sort of warranty. Here's the website, http://www.adsitco.com/category.asp?CID=1645 GOODLUCK!
Old 12-13-2009, 04:20 AM
mbnz's Avatar
1990 300E
That looks like a good source.
As some of the other gears were showing wear too, I got mine fully rebuilt. The cost was $1900. If you are going to keep the car, it makes sense to do the full rebuild.
Old 09-14-2011, 11:47 PM
GORBETTTEAM's Avatar
'95 3.2 M104
Cool
guys... my transmission just did the same thing as all of you described but since I knew about it before... I didn't freak out... but instead I open my wallet and thinking about my (economical) options.
I think i'll trade my.... for a Honda
Old 02-14-2012, 07:55 PM
Cartagena's Avatar
1990 300E No Reverse Gear
I just bought a 1990 300E black on black (just had to have it) but it has no reverse gear. I just finished reading all the posts and will have to hope that a 300E shows up at a scrap yard. Thanks for all the great posts.
Old 02-15-2012, 03:40 AM
funkgab's Avatar
1987 300E, 1995 C280
where are you located cartegena?
Old 02-15-2012, 09:39 AM
RHW
RHW's Avatar
94 Wagon and 94 Cabriolet
BEWARE of that link to www.adsitco.com many many many problems, do a search, but don't use them.
On my 92 300e, reverse started slipping. My mechanic told me $800 to fix reverse seal only, and the rest of the tranny is often good for a long long time. Car had no further issues for 3 years and ... was sold to a friend in November who has had no issues.
Same mechanic replaced upper wire harness, but, said lower harness is comprised of a small amount of wire affected under the hood (heat) and he replaced ONLY the wires affected by heat - did not replace the elements of that harness that are not near engine. Cost $100 for lower harness solution. Too recent to say whether it was a good solution, time will tell.
I do not wrench, but, he was an MB mechanic when these cars were sold, and both solutions appeared to save costs without causing trouble.
Old 02-19-2012, 08:32 PM
ZaxW126's Avatar
1980 Mercedes 280 SE W126, Euro spec car! 1995 E320, payed $500 for it!
Over the years, I have repaired a number of these transmissions for this issue. It is usually a bad seal on the reverse apply piston, which causes a soft engagement of reverse, then slippage of reverse, and then subsequent rapid wear of the clutch plates. I just acquired a 1995 E320 6 weeks ago with this problem, and fixed it for a song. Being a tech, I didn't have to pay for labor, just parts. I usually get about 10 hours labor to fix reverse, reseal the front pump, and some of the other more common external leaks. I also check the clutch plates in the K-1 drum for wear while I'm at it. They are usually O.K.. --Zach
Old 05-24-2013, 10:18 AM
Ngarover's Avatar
'85 300TDT, '99 E320 wagon, '87 300D, '94 E320 '00 Landrover '95 landrover with om617.
As I just bought a 94 e320 with this issue yesterday, I'll hit you up for help if your willing.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: No reverse - transmission problem
