E-Class (W211) 2003-2009
DIY - Replacing Cabin Filter 2009 E350
Old 10-24-2009, 05:31 PM
WhipE350's Avatar
2009 E350 Sport Black on Black
I've included a document I put together after learning how to replace the cabin filter in my 2009 E350 Sport. Hope this is helpful.
If anyone notices updates or corrections that are needed I can re-post it. Next I'll do the oil and filter...after that the air filters.
Old 11-21-2009, 03:29 AM
rmeneses's Avatar
07 E350
Thank you, I'm going to replace the filter on the 07 E350 we just brought home because it smells like roses every time I turn on the A/C...
Old 11-23-2009, 06:41 PM
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
thats a good thing haha....anyways is this same for 05 E500?
Old 11-24-2009, 01:06 AM
WhipE350's Avatar
Djrabbi, sorry took so long to reply...appears mbworld is blocking bellsouth ip's...should work for your 07. Were u able to change it?
Old 11-29-2009, 06:25 PM
jlok's Avatar
2006 E350
Will try soon
Thanks for such detailed document, I also have the rose smell in my car, will replace the filter soon.
Old 06-19-2011, 01:44 PM
Patrick Manpous's Avatar
Thanks!
Great document. Thank you!
Old 06-19-2011, 02:36 PM
WhipE350's Avatar
Patrick, you are most welcome...getting time for me to do mine again, time goes so fast, been a year and half since I did that...wow!.
Old 06-21-2011, 12:57 PM
btv94's Avatar
2007 E350 RWD SP1 (M211.056/E272.964)
I just got the filter yesterday and will replace it tomorrow. Will confirm if 2007 E350 using the same procedure.
Old 01-14-2012, 04:38 PM
ozusa's Avatar
2004 E320 4matic Sedan
I just did my Aug, 2003 E320. It was easy.
The filter was $31.95 from my MB dealer. Part No. A-211 830 00 18 64
Some comments:
1) Unlike the photos provided above for later models, on the 2003, there is no cover with screws over the filter housing. You have direct access to the housing. It has a decal on it saying the battery is in the trunk
2) The only fastener was the 10mm nut on the front. Access to the nut is perfectly easy
3) The "clips" mentioned did not need much persuasion with a screw-driver. It lifted out quite easily. I was surprised
4) This filter simply cleans the air as it enters the cabin. If you are recirculating air, it will not pass through this element. Therefore, don't expect replacing THIS filter will clean cigarette or other odors from the cabin
5) The hardest part, and it isn't really at all hard, is removing the filter element from the filter housing once you have removed the pair from the car. There is another clip on the housing that you need to lever apart a bit to get the old element out and to get the new element in to go in. Not that difficult.
If this job takes you more than 15 minutes, I'd be surprised.
Old 01-15-2012, 05:40 PM
Sebfto's Avatar
E240
there's a youtube diy also http://www.youtube.com/watch?v=lmE8tvu-RDA
Old 07-13-2013, 03:05 PM
dave2001auto's Avatar
84 300d 2009 e320 bluetec
Are there filters under the right dash for the 2009 E class?
I can't find them if they are there. See picture.
How do you get rid of the cigarette smell? It's been detailed by the dealer, but I don't know if they smoke between times. I can smell it on the MBtex seats.
Some comments:
Old 02-28-2014, 02:57 PM
paul ram's Avatar
2009 E350 Sport
Hello Whip350,
I too have the same car as you and thanks for an informative procedure for the cabin air replacement procedure.
I would like to add the following. After releasing the "clip" on the right side , I tilted the box upwards towards the underside of the hood and while doing so pushed it to the left. This released the box assembly quite easily. Space sure is tight on the left side even for my small hands!
Old 11-30-2016, 03:10 AM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Arrow
+2 on this question? Is the cabin filter ONLY on the passenger side engine compartment? I replaced that already but someone mentioned somewhere else that there was one located under the glove compartment... is this true with 2009's?
Thanks,
-Nigel
Old 11-30-2016, 10:29 AM
konigstiger's Avatar
Received 4,414 Likes on 3,144 Posts
'71 Pinto
MY09 has one cabin filter located in engine compartment.
NewShockerGuy (12-03-2016)
Quick Reply: DIY - Replacing Cabin Filter 2009 E350
