S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
'98 S420 won't shift from first gear...
Old 10-12-2009, 11:57 PM
BigBoss's Avatar
2002 Mercedes Benz E320
My cousin has a '98 S420, 126k miles. It's been sitting for a while, but it has always worked really nice. Now it just won't shift from 1st.
What could be the problem?
Old 10-13-2009, 10:42 PM
TMAllison's Avatar
09' E320
Guessing you have 1st, 2nd and R only. Is "limp home mode", caused when the trans detects an internal fault that could cause damage.
Needs to be scanned using SDS (MB laptop) or other very high end scanner capable of reading that module.
A good MB tech can view trans adaptations values and *see* how the trans has been recently adjusting itself internally to maintain quality shifts and determine the problem.
Ammco can't; and will only suggest rplacing with a rebuilt unit.
Might check the trans harness and see if fluid has leaked into it. Can wick up to the TCU and fry it and cause LHM.
P, R, N and D are mechanical. The rest is electronic.
Old 10-15-2009, 11:46 PM
BigBoss's Avatar
So is this like a dealer only fix?
Old 10-16-2009, 01:59 PM
TMAllison's Avatar
09' E320
Depends how handy you are.....there are times where the dealer with their high level of tech is the lesser of evils. Trans, at least as pertains to the diagnosis, is one of those times in my opinion.
Old 10-20-2009, 01:49 AM
BigBoss's Avatar
What do you think could have caused this? Long period of sitting?
Old 10-20-2009, 04:00 PM
TMAllison's Avatar
09' E320
Check the harness for fluid contamination.....if you find some, check the opposite end where it connects to the TCU in the computer box.
Old 10-21-2009, 03:05 AM
aje00325's Avatar
loveki
Valuable information.
Old 10-26-2009, 08:01 PM
BENZBOSS's Avatar
1999 S420 1994 S320 1994 E320
RPM sensor
Quick Reply: '98 S420 won't shift from first gear...
