o2 sensor bank 1 sensor 2 oem part#?
Old 10-09-2009, 05:27 PM
evatheprincess's Avatar
1998 e430
Red face o2 sensor bank 1 sensor 2 oem part#?
I have a 98 e430 starting to act up. check engine electronics light came on read code p141 and p136 o2 sensor heater circuit malfunction. bank 1 sensor 2.
questions:
1) which sensor is that (right passenger side, rear/post converter?)
2)can i just replace that single o2 sensor?
3)is this the right part bosch http://www.amazon.com/Bosch-13782-Ox...pr_product_top
4)can i use a replacement part/brand or stay with the bosch?
5)where is the sensor located on car if I want to do it myself? accessible from engine area or is it underneath somewhere?
6)could there be another issue or with those codes...will replacing that sensor clear it up?
Old 10-09-2009, 06:42 PM
ohlord's Avatar
PM me
your post cat o2 sensor is bad bank 1 is passenger side.
Bank 2 is drivers side.
bank 1 sensor 2 means that the pass side post cat sensor is going.
They are 100000mile units so you should replace all 4.
Dealer over 200 a unit.
www.autohausaz.com about $100
me $210 for all 4 with instructions.
you can get to the front ones via the hood
The post cats via a car ramp or floor jack and jack stands.
Your power will return along with up to a 15% INCREASE IN MPG.
WAITING ON O2 SENSORS will decrease the life of your cats as well as your mpg and performance.
You need 4 2 pre and 2 post. I don't know about those amazon folks at times 3?????
Them $310 for 4
Old 11-15-2010, 03:54 PM
bseal's Avatar
2001 E320 wagon base
Them $310 for 4
I have a 2001 e320 benz wagon and read your comments on o2 oxygen sensors, I would like to know where do you buy your parts from,I need to replace all 4 one time asap.
Old 11-18-2010, 08:00 PM
TheBenzManE55's Avatar
2jzGTE Powered W210, 93 500E and swerv in a burb
bank 1 is passenger side and sensor 2 is after cat
part #000 540 81 17 or bosch # 13 782
list is $238.00 you can get some bosch ones online somewhere or i could get them for you if youd like
Dont use aftermarkets!!!!!!
Old 11-18-2010, 08:30 PM
allikanbe's Avatar
2002 E320
Should the O2 sensors just be replaced at a given mileage or do you wait for problems or codes? 2002 E320 96K miles
Old 11-18-2010, 08:36 PM
i would never replace them unless theyre bad, it doesnt make any sense to waste money on 02's that work
Old 11-18-2010, 08:50 PM
allikanbe's Avatar
2002 E320
Thanks. Didn't know if they were like spark plugs that you had to replace at certain intervals. I need to buy a code reader.
Quick Reply: o2 sensor bank 1 sensor 2 oem part#?
