Multiple malfunctions after wash | Stuck in 1st Gear | Electrical horror!
Old 10-09-2009, 11:20 AM
alkemist's Avatar
W220
Exclamation Multiple malfunctions after wash | Stuck in 1st Gear | Electrical horror!
I don't wash my car often.
Yesterday night I went to a very thorough wash, fully automated, took like 10 minutes just inside the brushes. I always liked it because it is very long and thorough.
Now I park outside for the night, today in the morning when I drive off, first I see airmatic warning in blue, then esp, then BAS, and the gears do not show on instrument cluster. So this is what it is telling me right now:
CHECK ENGINE LIGHT IS ON
ESP VISIT WORKSHOP
BAS VISIT WORKSHOP
AIRMATIC ^ VISIT WORKSHOP
ABS LIGHT IS ON
THE GEARS ARE NOT SHOWING UP
VEHICLE IS STUCK IN FIRST GEAR
GEARS/SUMMER/WINTER SETTINGS ARE NOT DISPLAYED ON INSTRUMENT CLUSTER, JUST THE CLOCK
So basically the car is a wreck. Not drivable, I cannot upshift or downshift, only between neutral, park, reverse and drive. Drive is stuck in 1st.
Solutions?
Did I flood my car? Is there a water collector maybe overfilled?
Water in the electrical?
Disconnect the battery?
Limp mode?
I will be checking the silver boxes under the hood for water damage. ekBenz posted that one is responsible for BAS, ESP, APS, the other for AIRMATIC. I tried disconnecting the battery and doing a reset with steering wheel turning, but this did not help.
I hope this can be resolved.
Thank you for youR help everybody,
Alex.
Old 10-09-2009, 04:10 PM
alkemist's Avatar
W220
I have checked three fuse boxes- 2 under the hood left and right, and one under rear passenger seat - all appear to be completely dry
No visible overflow of meshed drain under the hood. The hole is clean and compartment is empty.
Old 10-11-2009, 03:15 PM
cameraman123's Avatar
2000 Mercedes Benz S500 Designo
Moral of the story. dont use automatic car washes.
that being said, do a search, youll be amazed at all the similar stories on this forum.
Old 10-11-2009, 11:48 PM
Frank_S500's Avatar
SL63 (R230), CL500 (C215), SL55 (R129), CE300-24 Cabrio (A124)
Solutions?
Limp mode?
Alex.
Hi Alex.
Most likely is that the air intake for the AC is clogged and as result you have flooded the passenger room footwell with water, which created shortcuts to diverse control units.
Dry the car, clean the air collector and pray thats not getting too expensive.
Cheers, Frank
Old 10-12-2009, 12:23 PM
alkemist's Avatar
W220
Thanks guys, unfortunately I was unable to find a manual car wash in queens.
The check engine light went out so far.
No change in gears.
Frank_S500:
Thank you for the tip.
I want to find the air collector for the AC.
I've been looking through the EPC net diagrams and I cannot locate it.
Would you please point me in the right direction?
Thank you.
Old 10-12-2009, 04:30 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Its the area under the hood and just outside the windshield that I gave you the links to. Frank's thought is the same as mine.
Old 10-12-2009, 08:30 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
Wait... did you say you were in the brushes for like 10 min.. Wow i think everyones car screamed at once
Old 10-13-2009, 12:33 PM
alkemist's Avatar
W220
Hello gentlemen,
Yes, the car wash recently opened on Yellowstone and Metropolitan is kind of long. Longer than any other Ive seen before. Just to pass through the brushes probably takes like 7-8 minutes, maybe even more.
Skylaw and Frank,
Are we talking about the water reservour covered with meshed plastic? (Looks like it collects the water which accumulates on the hood)
That is the one I cheched, there was no water there and the drain hole seems clean. I took the meshed plastic cover to make sure.
I thought Frank is talking about something else, sorry.
Old 10-24-2009, 01:15 AM
alkemist's Avatar
W220
UPDATE / FOLLOW UP
The car was taken to a shop for a scan, which turned up 2 problems so far:
1) Water damaged electronic transmission control module ( A 030 545 20 32 "EGS52" SIEMENS # 5WP2 0000AR)
2) Communication error between Ignition switch and the computer responsible for all those functions which are giving me errors mentioned above (do not recall its name, but it sits in left engine bay fuse box, all the way to the left, silver box)
So to get it out of limp mode, I have to get and program new transmission computer, then I will work on all other errors.
Transmission control module has obvious signs of water damage on the circuit board (probably there from last owner). I will try to clean it up and see if I can get it to work, but if some capacitor or other is fried, I am doomed.
New one at dealer is over 900 bucks. I need used one fast. Any assistance as to where I should look is really appreciated.
In addition, the mechanic is telling me the new computer will have to be programmed. Can I avoid this somehow? His rates are 75/hr and he is saying programming will cost me around $150. Also, are some part numbers for this module interchangeable. I've seen a couple on Ebay, but none match my part number specifically.
Thanks everyone.
Old 10-24-2009, 02:41 AM
raymond g-'s Avatar
99 E320
took my brother's 00 E320 for detailing couple of months ago. he was
returning from Kabul and I thought it would be nice to have it clean etc.
when i went to pick up the car, it was in limp mode, and similarly, with
multiple codes. in addition, the display showing gear (123DRP) would
either be R, P or nothing.
aware of the trans control board issues etc....i just stopped driving it
once I got home. I opened all i could to expose the board. hair dryer
pulled out, fan etc. left the air flowing all night.
following day, the codes automatically extinguished, but the gear display
was still erratic. left the panels open and more air time. no longer in
limp mode.
day 2, all returned to normal.
i was lucky
Old 10-24-2009, 04:49 PM
alkemist's Avatar
W220
Good news guys,
I dried tranny circuit board over night; heated it a bit with my 300w light bulb, removed corrosion due to oxidation with a toothbrush, cleaned the circuits with rubbing alcohol, reinstalled. First think I noticed gear info came back on instrument cluster, once I was driving all Other errors went away naturally. I hope it stays this way :-)
Old 05-31-2011, 10:45 PM
vipercc68's Avatar
2000 S430
Is the car still working? Did you get a new TCU or a used one?
I have a 2000 S430 in limp mode. Changed the tranny. Same problem. Changed the TCU still same problem. Just trying to gain insight. Thanks!
Old 07-21-2012, 09:06 AM
spaceengineer's Avatar
s430
Do you got any error messages?
Old 11-06-2015, 08:00 PM
vipercc68's Avatar
2000 S430
Limp Mode Fixed
the traction control computer was disconnected
Rate This Thread
Rate This Thread:
Quick Reply: Multiple malfunctions after wash | Stuck in 1st Gear | Electrical horror!
