CLS Coupe (C219) Discuss the CLS Coupe.
DIY CLS550 Engine Air Filter Replacement
Old 09-22-2009, 06:51 PM
ppilot's Avatar
'20 CLS450; '14 CLA250; '14 Honda GX Natural Gas Powered
You will need Two Purolator A34838 filters available at Pep Boys ($18 each) or other supplier. Pull up and remove the Front Plastic Engine Cover. With a screwdriver pry back the wire clip on the back center of the Rear Plastic Engine Cover, and disconnect two air intake tubes and another smaller tube. Then pull up on the Rear Plastic Engine Cover Lift off entire cover and flip over to expose 4 Torx screws on each filter box (you need a Torx tool, it’s something like an Allen Head wrench) to expose the filters. NOTE: These are the Engine Air Filters, NOT the Cabin Air Filter. E-mail me for pics if you like ppilot5@hotmail.com
Old 07-05-2010, 03:29 PM
docgizmo's Avatar
cls550
cls550 air filters
That really works, I installed two K and N filters 33-2181. Need to work it a little.be carefull on the air inlet tubes.
Old 07-05-2010, 03:59 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
It's the same procedure on almost any MB, not difficult. Don't know much about Purolator but I think you should stick with OEM, K&N, Green, BMC. First time I h ave heard those used in an MB.
Quick Reply: DIY CLS550 Engine Air Filter Replacement
