water inside car when it rain
2017 GLE350, 2009 ML350 4matic, 2005 4maticWAGON (sold), A Pre-facelift W210(sold)
Rain water gets inside the rear driver's side door when it rains.
any suggestions on where to check for leakage or damages??? thanks
Check the door drains on the bottom
of the door.And also check under your seats in case the dreaded battery box water intrusion has occurred.
rain gets inside car
Thanks for responses....
This happen even car is parked...
Whenever it rains, I think it drips down the rubber strip..its seems like water drips by the lower part sit door and wet water on the bar frame directly under the door when door is closed.
I will call benz and give a feedback....
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Sunroof drains have been known to become clogged. Open the sunroof and check to see if there is organic debris near the drain holes. If not run a flexible something down the drain holes to see if that helps.
