S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Seat gear teeth broken need help replacing!
Old 08-21-2009, 10:55 PM
jman92627's Avatar
S500
Hi all,
I have a 1997 S500 and the drivers side seat back gear that is driven by the motor has two broken teeth on it! I am lost as to how to get it out to replace it, it seems to be part of the seat back pivot and has a strange square drive head on it and secondly does the dealer even sell these gears or anyone know where to find one! The seat is a disaster not only does the motor spin and grind when it gets to the broken teeth, but the seat back is now lopsided because both sides of the seat back do not move together. Help, I can't even figure out how to get the gear out!
Thanks so much, I am desperate on this one! I'm also in Los Angeles if anyone knows of a MBZ salvage yard around here.
Old 08-24-2009, 10:48 PM
panasonic's Avatar
car
Thanks for the comment bigbird. I couldn’t agree more. A little helpful information never hurt anybody!
comparatif simulation taux credit auto - Taux crédit auto. Comparatif des offres! Les meilleurs taux crédit auto sont sur le net !comparatif simulation taux credit auto
Old 08-25-2009, 12:38 AM
BENZBOSS's Avatar
1999 S420 1994 S320 1994 E320
Old 08-25-2009, 12:58 AM
jman92627's Avatar
S500
Thanks Boss-
I was actually having a problem with the driven gear that controls the seat back. It is located in the seat back, rather than in the base. I found the solution, the gear cannot be replaced on the seat (there are two of them), one has to buy a new back frame for $500 from MBZ, shipped in 2 months from Germany. I bought a used seat in perfect condition for $100 and just switched the frames out. The problem is the drive gear on the motor is metal and the driven gear is a plastic gear that probably fatigues over time...1 missing tooth is enough to kill the backrest and list the seat until it kills your back.
Thanks-
J
Old 08-10-2013, 05:43 PM
dbs600's Avatar
Thanks for this thread, jman.
I have the same problem now.
Can you please post a more detailed repair procedure?
Quick Reply: Seat gear teeth broken need help replacing!
