CLS Coupe (C219) Discuss the CLS Coupe.
Replacing Steering Wheel Angle Sensor
Old 08-12-2009, 03:26 PM
SixthGear's Avatar
cls500
Does anyone have pictures of where this unit is located? I've read the posts and it seems that this is the probelm with my car (ESP non-functional, active headlights non-functional, and cruise control non-functional). Also, the MB part number I found is MBN 171 545 10 32, is this correct?
I have a '06 CLS500 with around 10,000 miles.
Thank you in advance!
Old 08-13-2009, 12:13 AM
khelawanb's Avatar
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
Only 10,000 miles? WOW! Hope you fix the problem.
Old 08-13-2009, 01:18 AM
Kar don's Avatar
Mercedes-Benz
typically its on the steering column behind the wheel.. you have to remove the wheel to do this. Take it to the dealer.
Old 08-13-2009, 10:45 AM
SixthGear's Avatar
cls500
Thanks guys for the help. I really dont want the dealer working on the vehicle if the fix is so simple. From the other posts that I've read people are saying they are in and out of the dealership in 45 minutes. Anyone have a tech manual? I would love to do a write up on this as it seems this is a very common occurence.
Old 08-13-2009, 01:07 PM
konigstiger's Avatar
Received 4,417 Likes on 3,146 Posts
'71 Pinto
Originally Posted by SixthGear
Does anyone have pictures of where this unit is located? Also, the MB part number I found is MBN 171 545 10 32, is this correct?
I would suggest you have the dealer replace it under warranty. Current part # is 1715451432 (for comparison shopping, parts.com $120.75) see 80 in attached diagram. DIY you will need to remove steering wheel, air bag, contact spiral (90) and switch module (10). Battery does not need to be disconnected be sure to remove key / KG smartkey from area. Fault code(s) need to be erased and new steering angle sensor needs to be initialized with SDS.
Old 08-14-2009, 11:37 AM
SixthGear's Avatar
cls500
Thank you for the help! The warranty has expired on this vehicle, but I do know that the Star Diagnostic System will be needed to clear the codes. A MB tech told me that after the install you need to turn the wheel "lock to lock" in order for the part to understand true center.
Is parts.com the best place to buy MB parts? Are there any dealers that support the forums that sell discounted MB parts? Thank you for the advice, I truly appreciate it.
Quick Reply: Replacing Steering Wheel Angle Sensor
