Turning Navigation voice volume up?
Old 07-28-2009, 06:23 PM
LAWYER2's Avatar
15' W222
sometimes the navigation sounds too low. Is there a volume adjustment?
Old 07-28-2009, 06:27 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Yes
When the voice is speaking turn up the volume with the knob. It won't affect your music volume.
Old 07-29-2009, 10:12 AM
LAWYER2's Avatar
15' W222
you're referring to the round selection knob, and not the regular radio volume controls?
Also today I got a Navigation could not be started due to an error message, has anyone gotten this before?
Old 07-29-2009, 04:38 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
This is covered in your COMAND manual (for the '01), which I presume you don't have, since you're not reading it. You can download one at http://home.earthlink.net/~phdwebsite/comand_manual.htm
While navigation is active, you use the normal radio volume control either on the steering wheel or the COMAND unit. Both will work. If you can't adjust it quickly enough (while it is providing a command), hit the RPT (repeat) button and then adjust.
I have had the message you described on occasion; shutting the ignition down and re-starting after a short wait (30 seconds or so) re-booted the system.
Quick Reply: Turning Navigation voice volume up?
