Sunroof lubrication questions????
Old 06-18-2009, 01:32 AM
JimPap's Avatar
2008 C300 Sport, RWD, US
What kind of lubricant do you use on the sunroof of an 08 C300?
Also, where do you lubricate it?
We're having 97 degree days already and this year my sunroof make a funny noise when opening in a vertical direction. I don't recall it doing this in either 2008 or 2007.
Old 06-18-2009, 09:18 AM
TB5...'s Avatar
2009 C300 4Matic
i get that same noise...
like it's struggling to open.
i was thinkin i might use wd40... but ya i don't know where... ill have to take a better look at how it functions.
Old 06-18-2009, 10:57 AM
Egonvdv's Avatar
E 300 AMG-Line diesel-Hybrid - 2021
squeaking noise you mean?
i got that when it's really hot, but only when it lifts up.
once it goes backwards, it's ok
Old 06-18-2009, 11:59 AM
JimPap's Avatar
TB5,
Hold off till we hear from somebody who knows.
Some lubricants can degrade the weatherstripping. Problem is I don't know which.
Old 06-18-2009, 12:08 PM
TB5...'s Avatar
2009 C300 4Matic
you're right... i'll probably just deal with the noise for now.
Old 06-18-2009, 08:35 PM
Timeless's Avatar
2005 E55 ///AMG
The MB dealers have some sort of MB approved lubricant.
Old 06-18-2009, 10:29 PM
2-many-carz's Avatar
'08 C350
Months ago, I took my C350 to Phil Smart (Seattle) for the rear seatbelt recall and I mentioned the groan that the sunfoof makes when I tilt the back up. It doesn't always do it, but I have never paid close enough attention to figure out just when it does do it. Anyway, they lubed it and it still groaned, so they orderd and installed a new sunroof motor. It still groans. Maybe when I take it in for a service I will mention it to them again, but for now, I just live with it since it doesn't always groan.
Old 06-18-2009, 11:11 PM
RLE
RLE's Avatar
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
GROANING
Coincidence. My sunroof makes the same noise when it's hot and since Smart has my car right now, I'll inquire tomorrow about the latest fix.
NO WD-40!!!
Old 06-18-2009, 11:52 PM
08w204's Avatar
2008 MB C300 Sport (Mars Red)
Same problem here... I thought that I read in the Service B statement that they lube the cables for the sunroof. Could be mistaken but it's ringing a bell.
Old 06-19-2009, 12:27 AM
GateKeeper's Avatar
GLA45 AMG, GLC43 AMG
it's just the seals that expand and are tight, that make the sound, and only on hot days, the past few days it's been cold and damp and no noise, bet ya next week when it gets hot here in TO it will do it again.....something we live with, well at least I do, my pano roof in my X5 did the same thing, it did on my 535 as well, not a big deal, and no lube will help, as the lube will just dry out, and it will start doing it again.....
do the guys in the south have this issue, is it all the time, or not, how about when it rains and things cool down, does it go away ?
Old 06-19-2009, 12:46 AM
soldier2304's Avatar
C63 AMG(sold), 2009 CL550, 2010 S550 Majestic Black, 2010 ML550, 2006 C230, 2009 Venza
I get that annoying sound all the time, like it does indeed struggle to open It's quite annoying
Old 06-19-2009, 06:04 AM
Germanmarque's Avatar
W107, S500
MB Special Lubricant - For lubricating outer guide rail of panorama roof
001 989 50 51
MB Lubrication Paste - For cleaning outer/inner channel, shift gate, pivot arm of wind deflector of top sliding roof (panorama roof)
001 989 46 51
Apparently, this is also known as Klueber Polylub GLY 801
Old 06-19-2009, 06:59 AM
JimPap's Avatar
Do you need to use the lubrication paste first and then the lubricant?
Old 06-19-2009, 07:34 AM
W107, S500
The paste is to clean the guides, runners and assembly before oiling - if necessary to remove dirt build-up. The oil is purely for lubrication. The expensive part..the paste is around $220.00 and the oil slightly less for a bottle that fits in the palm of your hand! The bad news, you can use silicone spray, WD 40, vaseline on your sunroof, but according to Mercedes friends who work on them, they do a fair bit of repair work on sunroofs when people do use 'other than recommended" lubricants. They only use recommended as it works. You only need a few drops so it will last and so will your sunroof operation. I bought the oil, it's cheaper than the repair option down the track. Hope that helps.
Old 06-19-2009, 11:16 AM
JimPap's Avatar
$400 for supplies.
Well, is it covered by warranty?
Probably nothing special, we just don't know what substitues work.
Old 06-19-2009, 11:20 AM
TB5...'s Avatar
2009 C300 4Matic
wtf @ paying that amount for this issue... ridiculous.
Old 06-19-2009, 11:53 AM
nguyenmd350slk's Avatar
05-350slk and 08-c350
take it to the dealer and complaint, they lube it free - should be. unless the car is out of mfg warranty.
Old 06-19-2009, 01:07 PM
Super Moderator
Glyn M Ruck's Avatar
+1 - what Webasto needs to do is replace the plastic gear drive that opens it and always fails in the end with someting harder wearing. Proper lubrication will assist in prolonging this inevitable agony.
Old 06-19-2009, 06:37 PM
W107, S500
I replied in response to "Some lubricants can degrade the weatherstripping. Problem is I don't know which. ". This stuff from Merc does not, apparently most other lubricants do. It's advice, I didn't set the price - cheaper in your US $ compared to Aussie $'s anyway. Oils ain't oils and I don't have warranty mate!
Old 06-19-2009, 09:10 PM
who8888's Avatar
15 E350 4Matic
I have had that noise since the first summer I got my car. $400 I can live with the noise. Will just try not to open the sunroof during hot days. I usually use my AC anyway. I think once you have you AC on and you are crusing along on a highway, the noise goes away after it cools down a bit.
Old 06-19-2009, 11:28 PM
JimPap's Avatar
I'm more interested in opening the sunroof and windows before entering the car on a hot day to help the heat escape from the car.
Old 06-20-2009, 05:11 AM
Super Moderator
Any petroleum based lubricant would degrade the weather stripping.
Old 06-20-2009, 07:48 AM
JimPap's Avatar
I just googled treating weatherstripping and found in a Hundai forum that someone was recommending a silicone lubricant to treat weatherstripping. They also commented against WD-40 due to its petroleum base.
Anyone have any thoughts on using a silicone lubricant?
Years ago I had a tube of silicone greese. Is that the same thing?
Old 06-20-2009, 11:42 AM
Super Moderator
Yes - same thing. Castrol also sell a product simply termed rubber grease that would be safe on any product containing a proportion of natural rubber like weather strips.
Silicone is not the greatest lubricant but better than nothing. Be careful with silicone sprays because they frequently have petroleum carriers or propellants. Certain waxes & products containing teflon can be good in this application as can products developed for plastics lubrication in the electronics industry. You really want oils, greases & sticks for sunroofs. Aerosol sprays need careful consideration as to constituents.
Old 09-16-2009, 07:59 AM
928porsche's Avatar
2009 C300 Sport 4matic
Sunroof Noise and other problems
We have the same problem on our 09 C300 Sport 4matic. It has been in to the dealer 4 times already. Spoke to Service Manager yesterday, after giving them a bad review. He told me they were going to call MB and speak to phone tech about problem. I told him that should have been done the second time the car was taken in for the problem. This is our second MB we are very displeased with the car and service dept at local dealer. We have clear coat peeling off front bumper now. I called MB USA yesterday and spoke to them about Indiana Lemon law. The law states if the car has been in for service 4 times (in the frist 12 months or 12k) for the same problem and the problem is not fixed, then the car is a Lemon. I recieved a call back and it is being considered for a buy back.
Quick Reply: Sunroof lubrication questions????
