Old 06-09-2015, 04:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Door panels removal
Old 05-07-2009, 05:36 PM
Norm01's Avatar
2011 E550 Coupe
Door panels removal
Anyone have instructions on removing the interior door panels.
Old 05-07-2009, 06:01 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
I was trying to figure this out too (https://mbworld.org/forums/c-class-w...ff-before.html).
Here's a diagram courtesy of Vic Viper
I was planning on covering the interior doors with Damplifier Pro. I saw the two bolts under the handle, but that's as far as I got. I tried prying it a bit from the sides, but didn't want to break anything.
Old 05-07-2009, 09:27 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
2 bolts under armrest and pull firmly. Remember: there are wire harnesses to unplug (duh). This has to be one of the easiest cars as far as door panel removal.
Old 05-07-2009, 09:48 PM
Azn_C300's Avatar
Ok, so just those two bolts then? and just a firm pull? cool.
Old 05-07-2009, 10:29 PM
E350 Sport/ML350RWD
On the fronts remove the A pillar speaker grille before removing the door.
Sorry. Forgot about that.
Old 05-08-2009, 02:06 AM
2nice4me's Avatar
2011 E350 4 Matic
What does Damplifier exactly do for you? does it reduce more outside road noice or is it to improve the speakersound?
Old 05-08-2009, 02:15 AM
Azn_C300's Avatar
both. Damplifier Pro is the highest rated sound dampening material out there....blows away Dynamat Xtreme.
Old 05-08-2009, 09:31 PM
who8888's Avatar
15 E350 4Matic
Mike or Norm,
If you do pull all your doors apart, could you kindly try to see if you can tell what are the color of the wire that is feeding the bulb on the bottom of each door. I pulled one of the bulb out before but it was some generic blue flat ribbon wire. It must become some color wire at the edge of the door.
Old 05-09-2009, 06:37 PM
c350driver's Avatar
C 350
When you start doing that, could you post some pics online?
I'm am really curious as to how it looks, and if it;s hard to do!
Old 05-09-2009, 08:05 PM
Azn_C300's Avatar
I just finished the wheel well area and the top back (where the speakers are) in the trunk. PITA. Lesson learned....wear gloves. The aluminum foil is sharp. Sorry didn't take any pics of the install, but there are plenty on youtube of how it's installed. I kinda got lazy and didn't remove the trim around the wheel well and resorted to sticking pieces in through the access ports. Took it out for a spin and did notice a drop in sound and drone, but still could use some work. Tomorrow I'm going to do the trunk door and see how that turns out. Then if I need more, I'll start on the side doors.
Old 05-10-2009, 11:07 AM
aowhaus's Avatar
2008 C300 Sport 4matic
I really want to replace the amber LED in the door latch.
Thanks!
Quick Reply: Door panels removal
