Add 1 Liter Oil??
Old 03-09-2009, 10:38 PM
Lorinser55's Avatar
Lorinser 5.5
Add 1 Liter Oil??
Toward the end of every month my car is reading that it needs 1.0 liter of oil.
Is something leaking in the engine?? whats going on??
Old 03-09-2009, 11:42 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
What W220 do you have ? usually is normal and how often do you change your oil ?
Old 03-10-2009, 12:05 AM
ssonss1's Avatar
Flying Spur
i get that every month or two...i guess its normal...more so in the summer months...no leaks here tho
Old 03-10-2009, 12:35 AM
Gondon's Avatar
02 S500 Sport
Take a big crap into the Oil Pipe that should fix it
Yea you got an Oil Leak !
Old 03-10-2009, 12:50 AM
Lorinser55's Avatar
Lorinser 5.5
gondon your such a dikfor. Post crap thats useful not what you do to stop your problems lol.
Old 03-10-2009, 12:52 AM
Gondon's Avatar
02 S500 Sport
HAHAH
Old 03-10-2009, 12:57 AM
m4xm1l10n's Avatar
U nuts man lol !!! R u coming down to CT or Boston this weekend for the Meet ?
Old 03-10-2009, 01:31 AM
Gondon's Avatar
02 S500 Sport
wat meet?
People come to me , I dont come to people !
We should have another meet this sunday in LI haha.
Old 10-08-2010, 10:55 AM
i_am_amused's Avatar
2004 S55 (SOLD, miss it every day), 2009 GL550
bring this post back from the dead
my 2004 S55 popped up the same message, which stayed on for about 10 seconds then went away:
Add 1.0 liter oil at filling station
I've not seen this in the 17 months and 21K miles I've had the car. It's due for a Service A in about 1,200 miles.
It happened during WOT acceleration.
Normal?
Old 10-08-2010, 11:49 AM
Reckless's Avatar
Mercedes S600TT, LX470 SuperCharged, QX4, BMW 750IL
Happens to me every 4-5 months. Put oil in and it goes away. I was told to use 0W40. When it says add 1 Liter it usually means your engine is out of oil. I have never had any oil leaks... I think MB engines drink a lot of oil.
Old 10-08-2010, 12:57 PM
Oxygen's Avatar
W220 S65 AMG
Yeah guys... supercharged and turbocharged engines are going to burn oil... so um... add oil when it tells you to!
Old 10-08-2010, 01:34 PM
rondocap's Avatar
Mercedes S55 AMG
I get this too on mine, after an oil change 1-3 months, it will tell me to add 1 to 2 quarts of oil. I do have a minor oil leak in the rear seal, so it may be that as well.
Old 10-08-2010, 03:58 PM
Quadcammer's Avatar
96 and 08 911 turbos
id get a dipstick and actually make sure you need oil before actually adding it.
Old 10-08-2010, 05:44 PM
rondocap's Avatar
Mercedes S55 AMG
Oliverk, actually I was just about to say that. The onboard computer can and sometimes is wrong. You definitely need to manually check the oil as well.
Start the car up and warm it, then turn it off, wait 5 minutes, and check the oil with the dipstick. That's the best way, since the onboard computer can sometimes be a bit off. Also make sure the car is on level ground.
Old 10-08-2010, 05:48 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
Funny, I just got that same message yesterday, for the first time. I took it to my MB dealer and they topped it off.
During the last Service B, they put in too much, manual says 7.9 quarts, they put in 9 quarts, so they had remove some, possibly took out too much resulting in this error this time.
Anyway, they say 1 quart every 1,000 mile is normal, but should look out for leaks or burning oil.
Old 10-09-2010, 06:52 PM
JoeVal's Avatar
C350 Elegance
If there are no leaks, the oil lost is just a sacrificial film in the cylinder wall that is pushed out the exhaust pipe with the fumes of the combustion chamber. This loss is a result of the extraordinary lubricating protection given by synthetic oils which manage to penetrate even through the oil ring of the piston. A true benefit which helps extend the life of the engine about 25% by comparison to engines lubed with fossil oils.
So, if there is no trace of leak, leave it alone. However, I agree that the oil should be measured to check how much is needed to fill the system without going over the normal quantity.
Quick Reply: Add 1 Liter Oil??
