2004 E55 AMG dyno numbers - before and after...
Old 02-16-2009, 01:58 PM
Almo's Avatar
2005 E55 AMG
Before: Stock
After: Kleemann Headers, Pump, Thermostat
The Dyno is a DynoJet (in-ground at Excessive Motorsport - Northern VA - shop is a distributor for LET)
SAE:
Stock dyno peak numbers - 410/433
After dyno peak numbers - 447/472
STD:
Stock dyno peak numbers - 422/446
After dyno peak numbers - 461/484
Difference in numbers all the way across the curve was the same as the peak difference.
I believe I am getting headers now.
I will get the dyno sheet up soon as I get to my house.
Old 02-16-2009, 02:55 PM
bobgodd's Avatar
2004 E55
I have an 04 myself and my first mod (and only mod so far) was a set of headers. Though I haven't had it dyno'd, I can absolutely feel a sizable difference in performance.
Old 02-16-2009, 05:55 PM
Mathmik's Avatar
14-F Sport, 07-CLS63 2003-HUMMER 2004-Suburban 2008-MAX 2005-YZF R1
nice numbers for sure
Old 02-16-2009, 06:50 PM
prodigymb's Avatar
997TT, R8 V10+, G550, Plaid S
after i get a tune for what i have my next mod will definetly be the kleeman headers. that is a solid gain.
Old 02-16-2009, 11:29 PM
HYEPWR's Avatar
2011 Black C63 Eurocharged V5
they happen to put a wideband on it? Id be very interested in what the AFR looked like before and after the headers. Andy from MHP asserted that he didnt think that headers were worth much and that most of their gains are from a leaner AFR. Id like to see if your data supports or refutes this assertion.
Old 02-17-2009, 09:27 AM
Almo's Avatar
2005 E55 AMG
Actually, headers will lean a car out a bit but the gains shown on the dyno for the header install (other couple mods) weren't off a more lean AFR alone, "what goes in must come out" theory shows headers and or larger exhaust does an FI engine good and will always provide good gains across the curve. Of course, NA motors are a different story and will not yield as much of a gain compared to FI engines. Maybe this is why Andy stated what he did seeing he might have been speaking in line with his C63.
The AFR is reflected on the dyno sheet and I must say it was pretty.
I forgot to grab the dyno sheet when I left yesterday but will get it tonight, take a good picture host/toss it up.
Old 02-17-2009, 01:09 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
nice gain!
now u need pulley and LET tune...
Old 02-18-2009, 11:54 AM
deshelto's Avatar
2004 E55
Dyno Sheet
The car that Almo is referring to is actually mine. The guys at Excessive Motorsport did a great job with the headers and cooling mods. The before and after dyno is posted below. Next up: 180 mm pulley and custom LET tune!!!
Old 02-18-2009, 12:34 PM
bobgodd's Avatar
2004 E55
That is an outstanding dyno sheet, and confirms my feelings that my car gained a decent more amount of power. Thanks for sharing.
Oh and I'm on the same track as you, I'll be going with a 180mm pulley and an LET tune soon enough!
Old 03-06-2009, 03:24 PM
chawkins2001's Avatar
2006 E55 AMG
so this was headers only, no tune?
Old 03-06-2009, 03:36 PM
deshelto's Avatar
2004 E55
Yes, no tune, no K&N filters, nothing.....I am waiting to get a pulley. Then I will get a custome LET tune.
Old 03-06-2009, 08:29 PM
jangy's Avatar
2015 S212
Very nice numbers. didn't you have to flash the ECU for the o2 sensor? Did they (Kleeman) just flash for the code and leave the tune? Either way, nice A/Fs.
Old 03-07-2009, 02:07 PM
prodigymb's Avatar
dyno and a/f looks great
Old 03-07-2009, 05:42 PM
2006 E55 AMG
I just ordered mine to after seen this. Cory said they just tune out the primary cats and fool the computer. This is with the stock tune, headers only.
Old 03-08-2009, 05:51 PM
deshelto's Avatar
2004 E55
Exactly.....and there is a nice increase in sound as well. Not too obnoxious, but enough that you notice a difference.
Quick Reply: 2004 E55 AMG dyno numbers - before and after...
