Question about Neutral Saftey switch
Old 12-22-2008, 09:32 AM
GEDaggett's Avatar
1994 E320 (current)
My Neutral Safety switch has not aloud me to start the car from park for about 2 months. Recently after driving in 5 inches of snow (may not be related) I could start it from park about 80% of the time. Yesterday I went out to start her up (-2F degrees) and It wouldn't start in P or N. There is plenty of juice in the battery and the starter makes no noise at all. I was wondering if in your experience the Safety switch problem can eventually foul up the neutral starting position as well. It may be that the points on the starter got moisture and then froze up. I am going to try and thaw it out and smack it a couple times and see what happens but let me know what you know.
Gary
Old 12-22-2008, 06:28 PM
TMAllison's Avatar
09' E320
Once they begin to brain fart they will eventually fail completely.
Get a new one; is easier than dragging a hair dryer out to the car every morning.
Old 12-22-2008, 11:24 PM
Federic0W124's Avatar
1992 400E
throwing this out there but check fuse 5 in the engine compartment.
Old 12-22-2008, 11:54 PM
GEDaggett's Avatar
1994 E320 (current)
I will check that. Thanks. Also is it true that the Tranny has to be dropped to replace it?
Old 12-23-2008, 12:16 AM
vanwiek's Avatar
'16 E350 ‘07 S550 ‘21 GLE580
No, I replaced mine with the tranny in the car.
Old 12-23-2008, 02:50 PM
GEDaggett's Avatar
1994 E320 (current)
What kinda time did it take you?
Old 12-23-2008, 03:04 PM
124-Fan's Avatar
Mercedes Benz
This switch failure isn´t uncommon. It also engages the backing up lights. It is not hard to raplace. Last time I did is was some 30 mins or so.. upon a lift.
It is retained by two bolts, but you must undo the shift lever first.
-Note, that there is room for some freeplay at the bolt holes when you install it. That is so yo can adjust it to function in all positions.
Usually the centre placement will do.
Cheers,
Old 12-23-2008, 03:59 PM
GEDaggett's Avatar
1994 E320 (current)
Where is that thing located on the trans
Old 12-23-2008, 04:53 PM
124-Fan's Avatar
Mercedes Benz
Here it is, on the left side.
Cheers,
Old 12-23-2008, 09:44 PM
GEDaggett's Avatar
1994 E320 (current)
Cheers,
Thanks. The stupid thing finally died in the driveway which would have been fine had it not been for the 8 inches of snow on top of 2 inches of ice with a wonderful layer of frozen slush as a base (gotta love Chicago) my driveway is on an incline so pushing it into the Garage is a no go and it is so cold if I push it in with my FWD van I will shatter the plastic on the bumper.......so I will be on my back in the driveway to do this one. It will be a blast.
Old 12-23-2008, 10:16 PM
vanwiek's Avatar
I'm not sure this will work but it might be worth a try before you submit to working in the frozen hell that is your driveway. Check out the attached pdf. If you apply 12+ to the vio/wht wire at the starter with the key in the run position the engine should start, you'd be bypassing the neutral safety switch.
I don't know if it would be any better to be down on the cold ground to do this or to replace the switch. I know when I replaced mine it took me an hour or two to get the old one out, the new one in, and then to get it adjusted so that the car would start in P or N and have the reverse lights come on when in R.
I'd think you could get to the starter harness fairly easily.
Just thought I'd throw this idea at you.
File Type: pdf
Old 12-24-2008, 06:34 AM
fred1948's Avatar
2005 E320 CDI
I replaced mine and would not recommend doing it unless you can get into the garage. There is very little room to work and I fear someone would find you frozen to the underside of your Benz!!
Jack up the car and remove the connector to the NSS and insert a jumper between pins 3 and 8. This should allow you to start the car and get out of the weather.
Do a search and you should find info on doing the job. Alignment of the new switch can be done by inserting a pin through a hole in the arm and switch. Also, there is a locking ring on the connector that needs to be rotated before the connector can be pulled off.
Old 12-24-2008, 08:59 AM
GEDaggett's Avatar
1994 E320 (current)
Thanks for the tips. I cleared the driveway last night and tried to start it one last time before I went all hillbilly on the work (I grew up in West Virginia so that wouldn't have been to much a stretch for me) She started right up and is now in the garage thawing out and I am going to put the switch in today. Dodged a bullet.
Old 12-24-2008, 08:54 PM
vanwiek's Avatar
Glad to here it.
Old 12-25-2008, 01:28 AM
GEDaggett's Avatar
1994 E320 (current)
Finished it up about an hour ago. Works great starts right up. Thanks again.
Old 05-18-2010, 05:47 AM
ANDYCOTTON's Avatar
1990 300E 4Matic
Does anybody know the part number for the NSS on a 1990 300e 4matic?
Old 05-18-2010, 02:15 PM
124-Fan's Avatar
Mercedes Benz
The number is A 000 545 49 06.
Cheers,
Old 05-18-2010, 08:47 PM
ANDYCOTTON's Avatar
1990 300E 4Matic
thanks! you're the best! around!
Old 07-27-2011, 05:38 PM
itstheshawnp's Avatar
1987 300d
does anybody know how to actually replace the nss without dropping the transmission? i read in this thread it can be done, but i dont really see how. i can barely see the area, and even my thinnest tools dont fit between there. im sure i can find some that may fit, but how are you supposed to make sure everything is adjusted properly being that tight? is there some sort of trick to it?
Old 07-28-2011, 12:28 PM
GEDaggett's Avatar
1994 E320 (current)
LIft the side of the car up and put it on Jack stands You can access the switch and replace it from underneath with the right combination of extensions on a 3/8 wrench if I remember correctly. Took me about 20 min.
Old 09-04-2011, 06:34 PM
jmonsterman7's Avatar
E320
Does anyone have more specific details on removing and replacing the NSS. I have a 94 E320, I just replaced the Wire harness and have video if anyone is interested. Thanks
Quick Reply: Question about Neutral Saftey switch
