C300 headrest removal- please help!!
Old 12-12-2008, 05:57 PM
rjdemoch's Avatar
2009 c300
09 c300- tried jerking, looked at front seatback for screws, there is a secret- please share with me.
(light grey mb tex soils Very Easily)
Old 12-13-2008, 09:10 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
I think you can only remove the rear seat head rests and only on cars with folding rear seats.
Old 12-14-2008, 08:38 PM
CarGuru's Avatar
'08 C 300 Sport, '01 SL 500 & '08 Nissan Frontier SE Crew Cab 4WD
My car does not have the folding seat and I have taken the rears out to clean the glass better. It's a PITA and slight design flaw with cars that don't have a folding seat but... Pull the rest all the way up and tilt it in the forward position. Then slightly pull it towards you. It will come out. As far as the front's not sure? Why would you ever need to take the front ones out?
-Ryan
Old 12-14-2008, 09:01 PM
C300Sport's Avatar
hmm...whats PITA stand for??
Old 12-15-2008, 02:09 PM
rjdemoch's Avatar
2009 c300
to install sheepskin
-Ryan
Old 12-15-2008, 02:52 PM
jstaneff's Avatar
C-300, XC70, Wrangler
Originally Posted by rjdemoch
To install sheepskin
Um, seam ripper, needle and thread. Open the top, slip it on inside out, sew it in place, then pull down over the rest of the seat.
Is the seat cover air-bag safe?
Old 12-15-2008, 05:03 PM
pakiplaya's Avatar
2008 c300 4matic
pain in the ****
Old 12-16-2008, 02:38 AM
che0x's Avatar
C300 Sport 4Matic
[QUOTE=rjdemoch;3216217]09 c300- tried jerking, looked at front seatback for screws, there is a secret- please share with me. ]
They do come out. I had mine out to install covers. There is an area on the side or back of the seat that you can push to release the head rests. I'll check for the exact location tomorrow.
Old 05-13-2009, 12:09 PM
Almost a Member!
eclipsin420's Avatar
2008 Mercedes-Benz C300 Sport 4MATIC
how do we put it back in without touching the rear tints that just got installed??
Old 05-13-2009, 12:29 PM
hutch300's Avatar
2022 GLE450
tints!!!!!!!!!!!!!!!!!!!!
now I think you mean tint
Old 05-13-2009, 01:32 PM
Almost a Member!
ya, tint...
Old 06-23-2012, 10:52 AM
dutchpt's Avatar
2008 C 300 sportmatic
What is the secret????I can't find the screws!
Old 09-23-2013, 11:06 AM
lorena42_D's Avatar
2009 c300
[QUOTE=che0x;3221732]
does anyone know how to remove the passenger headrest on a c300 2009??? please help! my seatbelt is locked around it and it has become a nightmare!!
Old 11-12-2013, 10:42 AM
sa.va's Avatar
2012 c300 4Matic
2012 c300 front headrest removal directions
Front headrests can be removed by following these steps:
1. Take seat's back cover, starting with 2 lowest clips, then sliding the cover down.
2. Unplug the electrical connector (that goes inside the sliding rod) and take it out of the holding clip (to avoid damage when pulled)
3. Gently push both sliding rods up until it stops. The pin on one of the rods would not let it slide further up – you have to use flat screwdriver to release the pin while pushing rods up.
4. Once rods moved approx. ¼ of an inch use regular button on the top of the seat to release and pull out headrest. BE CAREFUL not to pull it too hard to avoid damage to the wire.
Old 10-14-2014, 03:56 AM
exceptiontoall's Avatar
E350 2dr coupe 4matic
'12 c300, non folding seats,rear head rest comes out
We still have a my first 2012, C300 sport, 4matic, non folding back seats. You have to pull rear head rest all the way up, then (if sitting in backseat facing trunk) you pull hard, the right side of head rest will come out allowing you to turn it clockwise for a better position for head rest to come out. The right side of the headrests are shorter than they are on left side, but it's great they will turn clockwise from parallel (with back seat) to 5 & 11. We took them out super easy after figuring out correct way! Best of luck, hope this helps!!!
Last edited by exceptiontoall; 10-14-2014 at 04:00 AM. Reason: Forgot to put rear head rest
Quick Reply: C300 headrest removal- please help!!
