Source for spark plugs?
Old 11-10-2008, 09:54 PM
ZorroAMG's Avatar
Enzo, my Benzo
PARTICULARLY Bosch H9DC0's NOT the HR9DC0's
Stupid frigging resistor spark plugs are everywhere and I can't find any original NON-RESISTOR bosch ones.
Also could use:
NGK BP6EFS (as per RBYCC's suggestion)
Champion S12YCC
Beru 14 K-9 DU0 from kingsborne but apparently they arent reliable to order from...
HELP!!
Old 11-10-2008, 10:21 PM
YNVDIZW124's Avatar
lots of cars
If you would pay for shipping to canada i'll try to get some in the morning.
Old 11-10-2008, 10:28 PM
ps2cho's Avatar
E
http://www.mercedesshop.com/shopforu...d.php?t=181047
Old 11-10-2008, 11:01 PM
YNVDIZW124's Avatar
lots of cars
I should buy the last stock of h9dc and h8dc plugs from my local parts distributor huh...
Old 11-11-2008, 12:13 AM
ohlord's Avatar
NGK
TR5GP The resistor is only 5K ohm and your coil can shoot through that and you never know the difference.
Have you checked your spark plug wires resistance? A new set is only $80 bosch oe
I don't think you will find any BP6EFS
Fastlane is running out quick,if you absolutely positively must have the last of the H9DCO's
remember no anti seize
someone could mail you some.It only cost me $6 postage to send a 17mm M112 m113 spark plug boot removal tool up to Dunster and you are way closer than that.
Old 11-11-2008, 12:20 AM
ZorroAMG's Avatar
Enzo, my Benzo
Arrgh..more things to consider, ohlord?? Anti seize?
Hmm...YNVDIZ, you have 6 h9dc0's locally? I'd pay you for your time as well. I'd like 12 if you can get them....just so I don't have this issue again.
Should I get new wires too? Best brand and part #? I had a dude look up which wires were needed for my car and he quoted $200 lol
Old 11-11-2008, 12:33 AM
ohlord's Avatar
The guy
quoted you List price and www.autohausaz.com sells them shop price.80 bucks.Free delivery down here
Anti-seize: people used to use it on the plug threads before the new generation of plugs came out that are coated with a trivalent metal anti seize
plating so you don't use it any more and eliminate the risk of getting the old stuff on the electrode and shorting it out.
Have someone get you the wires and plugs and label it Gift
or see if autohausaz.com ships up.
Old 11-11-2008, 12:36 AM
ohlord's Avatar
On the wire questio
You can test your wires resistence,but unless they went on fire or someone yanked on them to remove them from the plugs at some time in the past,they probably test out fine.MB used some good plug wires.
Old 11-11-2008, 09:13 AM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Also could use:
Champion S12YCC
HELP!!
Don Diego Vega
This dealer shows ten Bosch in the USA, not sure of shipping to Canada.
http://www.truckmod.com/directpart.a...rtnumber=H9DCO
I bought twelve NGK BP6EFS from this UK seller with no problems.
The BP5EFS listed below are an equivalent heat range to the H9DCO, whereas the BP6EFS is a step colder which I use in my TT.
http://cgi.ebay.com/NGK-spark-plug-B...dZp1638Q2em122
Old 11-11-2008, 01:11 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
I just got my plugs from autohausaz.com.
Old 11-11-2008, 01:43 PM
ZorroAMG's Avatar
Enzo, my Benzo
WHICH plugs? Check the part number on the actual plug and box please!
Sometimes they've said they were sending H9DC0's but you actually get HR9DC0....R stands for Really crappy for M103's
Old 11-11-2008, 02:33 PM
Kestas's Avatar
I checked the box. I got the F8DC4 non-resistor plugs specified for my vehicle.
I don't think they carry H9DC0 plugs. You didn't specify which model you drive, so you'll have to double-check yourself.
Old 11-12-2008, 05:01 PM
ZorroAMG's Avatar
Enzo, my Benzo
I have a 1990 300E....will the F8DC4 work too if my car has H9DCO?
Old 11-12-2008, 08:52 PM
Benz260Benz's Avatar
1988 260E
Hey I could get you the plugs too, and wires, if you wanted; non-resistor (which is what I just put in mine) and for the cheap price. sounds like you have some other options to go with but I thought I'd let you know I could help you out since I'm just across the border.
Old 11-12-2008, 09:15 PM
ZorroAMG's Avatar
Enzo, my Benzo
Thanks my friend! Which model plugs did you use?
Old 11-12-2008, 09:44 PM
1988 260E
The Bosch plugs I believe
Old 11-12-2008, 09:53 PM
ZorroAMG's Avatar
Enzo, my Benzo
Have the box or receipts by any chance?
Old 11-13-2008, 09:10 AM
teezer's Avatar
1989 300ce
sitting on a bunch of nos bosch H9DC copper core ~~~ 6 for $26 with free shipping to U.S.A. only ~~~ Canada ??
pm if interested ~~~
Old 11-17-2008, 02:25 AM
ps2cho's Avatar
E
I linked you to where you can get them for $3 each...
Old 11-17-2008, 06:04 AM
childofjuly's Avatar
1995 E 420
will the H9DCO also work on the M119?!
Old 11-17-2008, 06:12 PM
Almost a Member!
A_G_L's Avatar
W124-1992 300D 2.5 Turbo
BMV in richmond
Old 09-04-2009, 06:28 AM
armikauto's Avatar
Renault R5, Kia Pride, MB C180
Bosch H9DC0 spark plug
I have NOS Bosch H9DC0
Old 09-04-2009, 06:38 AM
armikauto's Avatar
H9DC0 Bosch Spark plugs now available, limited qty only
Old 01-03-2010, 10:39 AM
RDM3's Avatar
1985 190e 2.3l
H8DC0 spark plugs
http://cgi.ebay.com/ebaymotors/ws/eB...m=370309871768
Old 01-03-2010, 11:35 AM
ps2cho's Avatar
E
How are the H8DCO different from the H9DC0?
Quick Reply: Source for spark plugs?
