93 300E - Need help w/ wiring diagram for radio
Old 11-05-2008, 12:02 AM
lukehill's Avatar
1993 Mercedes 300E
Question 93 300E - Need help w/ wiring diagram for radio
Hello all,
I just recently purchased my first Mercedes - a 1993 300E. So far I'm loving it, but I've run into one problem: the stereo. This car was one of the models that had the Becker radio w/ the control unit, amp, cd changer, etc. in the trunk. The current system is no longer working and I'm wanting to install an aftermarket stereo. I know it's a big job requiring some pretty extensive wiring, etc. and I'm fine with that, but the one thing I haven't been able to find is a decent wiring diagram for my car (I'd like to tap in to the existing speaker wires, radio power, etc.). I purchased the Mercedes Shop Manual software discs and have them installed and while they have a ton of information on my car, they don't seem to have a wiring diagram & neither does Becker. Does anyone know where I can find a wiring diagram for this car? Is there anywhere online or perhaps even a book that might have it?
Thanks in advance,
Luke
Old 11-05-2008, 12:43 PM
pmally's Avatar
87 300E, 82 300SD, 85 380SE, 1969 230,
here's a quick tutorial i will write for you
If your car has a fade control by the window controls you will want to rewire that for much better performance from there you can determine which wires are for the rear speakers. Your new aftermarket stereo will come with a wiring diagram to help you out its usually on the top of the unit. I have installed so many stereos in so many different types of cars I can guide you through it.
1. Just buy a volt meter and clip off the old wiring harness from the stock Becker. (you can get a cheap volt meter off the internet)
2. Find which wire gives the radio power while the ignition is off it will be the RED WIRE on the new stereo
* you will need to also find the ground (its usually black).
3. Turn the ignition to the ON posision and find the power wire it will be the YELLOW WIRE on the new stereo
from here you have the power taken care of, next you can wire the speakers up. if you have the fader then you will only have 4 wires to take care of they are usually color coded like green with a black line and the other wire will be green showing that they are a pair to power one speaker.
If you have any questions just ask
Old 11-05-2008, 12:44 PM
pmally's Avatar
almost forgot you will have a blue wire coming from the new stereo which will control your power antenna ( if yours isn't broken)
Old 11-05-2008, 01:36 PM
lukehill's Avatar
1993 Mercedes 300E
Thanks for the info! I do indeed have the console fader control (which I was planning on getting rid of and retro-fitting an aux input in its place). I think I should be good w/ the power, the antenna and the speakers, but I was hoping to tap into the power amp in the trunk to continue to power the door subs. I notice that the amp in the trunk just has one big connector block w/ all of the wires coming out of it - is there any way for me to determine which ones are the audio inputs?
Thanks again,
Luke
Old 11-05-2008, 02:34 PM
spinlps's Avatar
16 E350 wagon, 94 AMG, sold -95 E320 Sportline wagon & 94 E420 & 95 E320 coupe & 92 190 16v
Here are the scans of the two factory schematics that I have. If you need full res pics let me know your email address...
Attached Thumbnails 93 300E - Need help w/ wiring diagram for radio-scan0001.jpg   93 300E - Need help w/ wiring diagram for radio-scan0002.jpg
Old 11-05-2008, 02:35 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Here is all the Becker info...
http://www.beckerautosound.com/1432-1992-93/index.html
Old 11-05-2008, 04:13 PM
lukehill's Avatar
1993 Mercedes 300E
Spinlps - that's exactly what I was looking for. I've sent you a private message with my e-mail address. Thanks everyone for your help!
Old 11-05-2008, 05:20 PM
pmally's Avatar
the amp in the trunk would most likely have an accessory wire that would connect to the red wire on the new stereo so that it turns on when then ignition is on
Old 11-05-2008, 09:15 PM
spinlps's Avatar
I didn't get your pm, just email me @
spinlps@pacbell.net
Old 07-14-2010, 02:53 PM
BJaltima's Avatar
1993 400E, 1994 E420, 2000 SL500, 2014 C250
spinlps: could you please send me the high-res pics of the diagram to BJaltima@yahoo.com. Thanks.
Old 10-19-2010, 07:20 PM
tweenmwakibinga's Avatar
300e, 1991
yes i will the schematic diagrams
Old 10-19-2010, 07:21 PM
300e, 1991
please opload the schematic i nto my e-mail mwakenjs@aol.com
Old 06-14-2011, 11:52 AM
Brad Bjelk's Avatar
1993 300e 2.8
93 300e wiring
Does anyone still have the clearer version of those wiring diagrams? If so please email me them. z097988@students.niu.edu Thank you
Old 03-08-2012, 01:04 PM
chuang's Avatar
2004 C230 (sold), 1993 300E 2.8 (W124) (sold), 2012 C250 (W204) (sold), 2005 E320 (W211)
Sorry to revive this old thread. I believe someone said that usually one would need to purchase a 12' long antenna lead extension, as the current antenna lead goes to the tuner/amp in the right hand side of the trunk. And from there you need to run it up to the new head unit. Is this the only way to do it? I found it difficult to hide the long 12' antenna lead extension under the carpet, etc. Is there a speaker level wire under the fader control that I can hijack so that I can avoid running new antenna cables from the new HU to the trunk? Many thanks!
Old 11-07-2013, 06:06 PM
5o7190e's Avatar
1992 190e
Just came accross this thread, VERY helpful, I do have a request, would it be possible to get high res versions of those pics emailed? If so send to los5o7@gmail.com
Thanks in advance!
Old 12-25-2013, 11:43 PM
jeremybgood's Avatar
1998 MB E 300 Turbo Diesel
schematic /fader
Could someone on this thread send me the full high res schematic as well? Thanks! Bergolios@gmail.com
Also is it possible to leave the fader intact with aftermarket? I sort of like it.. Thanks!
Old 12-26-2013, 10:31 AM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
The high res radio schematics you are looking for are in the document here: http://www.w124-zone.com/downloads/M...am/ETM/ETM.pdf . See section 131.
Not likely. Old radio designs like the OEM one used single ended amplifiers where where the speaker outputs returned to ground. Almost all new aftermarket head units use bridged amplifier designs where both the speaker (+) and the speaker (-) carry active signal. If you try to hook a bridge design up to the fader you may damage the head unit or at the very least, you will only get 25% of the rated power output and the head unit will get very warm.
The reason for the change in design philosophy is only limited power output can be achieved on a 12 volt supply. With a single ended amplifier the theoretical true RMS power is limited to about 4 watts (with a 4 ohm load) whereas with a bridged design, the theoretical true RMS power is limited to about 16 watts. Becker and the later Bose system were know to use very low impedance speakers (2 ohms or even 1.2 ohms) to try and over come these limitations.
Most stand alone car amplifiers go back to the singled ended design (because they also contain there own internal switching power supply the provides "rail" voltages well above 12 volts), but their increased power output will vaporize the fader in a matter of minutes.
- FD
Old 12-27-2013, 10:12 PM
Fd,
Thanks! So if I wanted to keep fader my best bert is to talk to becker for a replacement?
Old 01-03-2014, 03:18 AM
alfajuj's Avatar
1993 W124 280E
Fd,
Please do not snip off the factory connectors as an earlier poster suggested! If you can get a suitable adapter, that’s ideal. Like if you are updating from an old 2 channel Becker to a more modern 4 channel one with modern connectors like a 1492, 1692, 2340, 2330, 4602, etc. In that case, you can use an adapter no.1163-736
But if you can’t, please just carefully tee splice into the existing wires without snipping off the factory plugs. That way it will be reversible.
Since your car is the type with the two piece radio and head unit, I would still suggest leaving all the factory wiring in place. You just need to run a few extra wires to make it work. To do this work, you’ll need to remove the wood center console panel at least. It’s probably easier to remove the whole center console.
All the needed power wires, antenna trigger wire, and the front speaker wires are still located up front. Once you hook those up, you just need to run wires to the rear speakers.
If you really want to keep the fader, you will need to repair your existing system or replace it with another old 2 channel one piece system like a 1480.
Old 05-21-2014, 07:20 PM
nesko's Avatar
mercedes benz 190e 2.6
Post
Hello, I have just become a proud owner of 190e 2.6 1993. My original car stereo died and I have bought after market stereo. Friend of mine had help me to install and now my radio is working with just two speakers (back ones). We could not figure out cable with six wire coming from car, which one is for the another two speakers ( my new radio has only four speakers option), and probably one wire must be for amplifier. That "cable" original has round connector. Please, help
Rate This Thread
Rate This Thread:
Quick Reply: 93 300E - Need help w/ wiring diagram for radio
