E-Class (W211) 2003-2009
SRS Light on...how to troubleshoot
Old 08-20-2008, 12:56 PM
ekm
ekm's Avatar
2015 ML250, 06 E320 CDI, 2008 GL320 (sold)
After 45K miles of no problems with my 06 CDI (other than tranny switch leak), my first issue with my car. Upon start up this morning, the SRS light comes on and displays a message on the speedo screen (service required or something like that). I shut the car off and go out and then restarted but same issue. Any way to reset this? Or how to troubleshoot this issue.
BTW...great car w Diesel power.
Thanks,
Ed
Old 08-20-2008, 04:33 PM
konigstiger's Avatar
Received 4,415 Likes on 3,145 Posts
'71 Pinto
Dealer needs to check it. May be DTB P-B-91.60/99d JUN07 SRS light illuminated, install Steering Control Module (SCM) repair harness/replace airbag line to SCM.
Old 03-17-2009, 01:22 AM
dochou's Avatar
E320
Hi Konigstiger,
What does "DTB P-B-91.60/99d JUN07 SRS light illuminated" mean?
Does that mean that this is a TSB and the dealer needs to fix it, even if the car is out or warranty?
I have this problem and the dealer said it would cost me $800 to fix.
He mentioned the SCM repair harness etc.
I told him that I would think it over.
What should I do?
Will this render my SRS nonfunctional?
thanks
Old 03-17-2009, 02:41 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Originally Posted by dochou
Hi Konigstiger,
What should I do?
thanks
The connector going to the steering wheel is damaged and needs to be extended. Unfortunately the problem will not go away and would probably cause at least your driver air bag to not deploy in an accident.
This unfortunately is not a recall but a DTB. It would be covered under the factory warranty or most extended warranties, but not covered if the vehicles it not under any type of warranty.
http://www.theworkshopmb.com/Thework...SRSlighton.pdf
Old 03-17-2009, 08:16 AM
morten's Avatar
220 cdi w212 t 2014
mine did the same . it was a broken wire under the driver seat . there are a plug with serveral wires in one off them broke off when the mech pulled it . he he just soldet it together and now all is normal again
Old 03-17-2009, 02:38 PM
dochou's Avatar
E320
So it's a known problem to MB but they will not fix it if out of warranty? Sucks!
I am out of warranty. So what should I do?
Can I fix it myself?
Can I take it somewhere else, besides the stealership? and an have an experienced mechanic fix it?
Thanks.
Old 03-17-2009, 03:55 PM
'71 Pinto
So it's a known problem to MB but they will not fix it if out of warranty? Sucks! I am out of warranty. So what should I do? Can I fix it myself?
Can I take it somewhere else, besides the stealership? and an have an experienced mechanic fix it? Thanks.
PM your email address and I will send a copy of the DTB inclusive of repair procedure. Then you can decide to repair it yourself, use an independent, or attempt a goodwill repair from MBUSA (not dealer) arguing factory routing of SCM harness caused the malfunction – may be tough sell though.
Old 07-19-2009, 02:51 PM
mark palmer's Avatar
e320
can I also have a copy of this DTB repair proceedure please, same problem on a 2003 e320 cdi
Old 11-16-2009, 04:13 PM
mbaumgarthuber's Avatar
e320,e300
could you also send a copy of this DTB repair procedure please, same problem on a 2000 e320
Old 11-16-2009, 08:56 PM
jdupa's Avatar
06 E350
the link posted above (#4) still works:
Old 11-17-2009, 08:10 AM
vettdvr's Avatar
03 E500 and Corvette
FYI I had a heavy book on my pass seat and it gave the SSR alarm. Moving the book cleared the alarm.
Old 11-18-2009, 12:46 PM
walter34payton2's Avatar
2006 e350
Is this a problem with all W211 or is it typically on the CDI models? I have a 2006 E350 still under warranty and am curious if I need to keep this in mind.
Old 07-26-2010, 02:50 PM
crazypotato's Avatar
E320 CDI
hi konigstiger... can you please send it to my email? thanks a bunch. I think your DTB is newer than the link posted here.
Old 11-20-2013, 10:31 PM
madaniann's Avatar
E500
SRS light came on after battery change
Hi konigstiger. This is an old post but I'm looking for a DIY guide to help me resolve my SRS issue on my 2003 E500. Could you send me a copy of this DTB repair procedure please?
My SRS light went on after a battery change. I was trying to find a power drain, which I did eventually, it was my AGW and I took the fuse out to fix the issue. I recently had the SRS fault code reset by my friend who has a body shop and a STAR scanner. The code went away for 10 minutes then came back again. If you have other suggestions please let me know. Thank you!!
Old 11-29-2013, 05:32 AM
madaniann's Avatar
E500
I figured out why the SRS light is on. I had removed the AGW fuse because I have a battery drain from the audio system, this causes the SRS light to come on. The light goes away when I put the fuse back in. Now I need to figure out how to fix the drain. I saw a post about a relay workaround for this problem buy there is no DIY for it.
Old 04-05-2015, 11:41 AM
Dwrightson's Avatar
2003 E320
2003 E320 SRS light comes on and off
I know this is an old post, but does anyone have the trouble shooting pdf talked about? The link posted now takes you to sales advertising.
Thanks,
Don
Old 04-05-2015, 02:24 PM
'71 Pinto
http://www.google.com/url?sa=t&rct=j...,d.eXY&cad=rja
Old 04-05-2015, 05:48 PM
Dwrightson's Avatar
2003 E320
E-Class SRS errors
Thank you. Do you know if this would cause SRS light to come on and off all the time? Or could there be another problem?
Old 04-06-2015, 11:37 AM
'71 Pinto
For definitive diagnose, you will need have someone pull fault codes using MB DAS.
Quick Reply: SRS Light on...how to troubleshoot
