E-Class (W211) 2003-2009
05 E320 CDI Battery - Visit Workshop
Old 08-19-2008, 04:18 PM
sl600_pilot's Avatar
2004 SL600, 2005 E320CDI
Thumbs down 05 E320 CDI Battery - Visit Workshop
after changing the battery i keep getting this message after we start the car.
after swapping in the battery, i needed to reset the panoramic roof, and the windows, but everything works well. except for the stupid message. got any ideas how to read a code or reset this?
I had to change a battery on my Sl600 and that was fine, change battery everything worked fine. so i am at somewhat of a loss.
I often remove the negative lead from the SL's battery to erase the adaptive shift and conservative fuel map when going to the track. never an issue.
can anyone recommend a code reader?
Thanks for any and all help
Old 11-02-2008, 12:07 PM
update
no codes are being set by system.
everything by code reader is a go.
i'm not impressed with the diagnostic at this point, ha
anyone have any ideals. car still runs fine. just have to reset the message after start and then once i put in drive. other then that thousands of miles and everything is ok.
Old 11-02-2008, 03:10 PM
Diesel Benz's Avatar
Which battery did you replace? Which code reader did you use? Star should give a good hint about the problem. It could be the front battery.
Old 11-02-2008, 03:32 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
SAME EXACT THING FOR ME!!! Ridiculous! I heard that it could be the relay, but as you said everything works fine and then after a bunch of miles (about 1000 as you said) code goes away. I guess sometimes its good to be stubborn.
Old 11-02-2008, 03:49 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Do a search on the battery control unit..next to the battery
Early w211s had problems with them
Old 11-02-2008, 07:01 PM
TPAbnz's Avatar
2017 E300W
Go to the MB god, Konigstiger for this topic:
https://mbworld.org/forums/showthrea...ght=sb+battery
Old 04-29-2009, 07:38 PM
jay m's Avatar
2002 E320 4matic & 2003 E320,
Hey SL600-pilot, I'm having the same trouble. I replaced the aux battery and the alarm is still present. How did you resolve this issue?
Thanks,
Jay
Old 10-15-2010, 07:53 AM
imkrn's Avatar
2003 e320 cdi
As a new forum member and proud owner of a previously enjoyed 2005 e320 I am curious if anyone has found a usable code reader. After being away for about 10 days I came home to 1 malfunction and the Battery sign visit workshop. I have always serviced my own cars but it certainly appears MB is way smarter than me. My code reader of couse shows no errors and the live data seems to function properly.
Old 10-16-2010, 08:43 AM
jay m's Avatar
imkern,
It has been a while since i tackeled the issue. If you do a search, you will find the thread on my repair. I do know that the light eventually cleared. I guess due to repeated cycles within the correct parameters.
jay
Quick Reply: 05 E320 CDI Battery - Visit Workshop
