SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: K40 relay module miracle
Old 08-07-2008, 04:08 PM
pmajet's Avatar
1999 SLK 230
Had the following codes. P1420, 1235, 1236, and P1525. As mentioned, suspect the relay. Took the module out and found bad solder points. Re-soldered and vola, check engine light went out and all power restored to car. Mercedes service center said it was the ECM and possibly the supercharger. Thanks for your suggestions.
Quick Reply: SLK/R170: K40 relay module miracle
