No playable files? Memory card
Old 06-17-2008, 11:37 AM
rebel_mtc's Avatar
1991 560SEL, 1981 300SD, 1983 300SD, 2008 C350
Question No playable files? Memory card
Hi guys I have a SDHC card with a PCMCIA memory reader but for some reasons the MP3 files doesn't play all I get is NO PLAYABLE FILES.
What am I doing wrong?
I try files directly from Ipod also try to convert them into MP3 files but all says NO PLAYABLE FILES.
Old 06-17-2008, 12:30 PM
cjh.'s Avatar
2008 C350
The files that you took from your iPod are likely protected files that have DRM all over them.
If the songs were purchased from iTunes, there is no way of getting them to work on that memory card. If they were imported from a CD, import the CDs into something like Windows Media Player and then put the files back on the memory card.
iTunes is really just bad news when it comes to using the media in other places than it and iPods.
Old 06-17-2008, 08:09 PM
Hazemonster's Avatar
2008 C300
Actually there is. If you purchased the music via iTunes, you can use iTunes to make "playlists" and then burn the playlists to CD-ROM. (iTunes allows you to do that) Then use a program like windows media player to turn them into MP3's. You can then put the MP3s on your SD card and into a PCMCIA adapter....then your Benz will play those MP3s nicely.
Old 06-17-2008, 11:23 PM
cjh.'s Avatar
2008 C350
I just tried this method. It does in fact work, however the artist/album/song info is lost. Not to mention its a PITA. And it breaks many DRM laws...I'm a goodie-two-shoes, I know.
The best option would be to use the AUX jack/iPod Adapter. I really don't know what MB was thinking with the PC Card slot. Since you know, EVERYONE these days has plenty of those things laying around. SD or maybe even USB, at the very least would have been nice.
Old 06-18-2008, 01:01 AM
white_glass_top's Avatar
2008 C300 SPORT (white)
I leave everything in windows media format, copy to the SD CARD, and it works just fine.
Old 06-18-2008, 01:11 AM
cjh.'s Avatar
2008 C350
Do you have an adapter for the SD card then?
To the OP- Sorry to hijack your post.
Old 06-18-2008, 01:54 AM
rs1985's Avatar
BMW E90, W204 C350
i don't know why
i got a SDHC card
and it doesn't work on my computer
do you guys think that it is SDHC so it can't work on the C Class ?
Old 07-01-2008, 12:23 PM
rebel_mtc's Avatar
Originally Posted by rs1985
i don't know why
i got a SDHC card
I think first of all your SDHC card should work on your PC.
If it doesn't work on your PC I doubt it will work on your C Class.
It doesn't have to be SDHC as well.
All just depends on your PCMCIA adapter.
I choose SDHC because I have a 8 gig already.
But so far still haven't get it to play music on the C-Class I think I have to try making the MP3 from my IPOD to WMA files.
Old 07-01-2008, 01:48 PM
hebsan's Avatar
2005 SLK 350 w AMG / 2008 C / 2019 A220
The "mp3" on your IPOD are not MP3. They are an Apple proprietary format. If you bought these songs off of iTUNES, there is no known way to convert to MP3.
If you imported songs via CD into iTUNES, simply copy the song files to the memory card. This is what I have done, and it works great.
On another note, if you are wanting to use songs of a CD, record it to the internal hard drive on the C300. I've recorded 10 CDs and have used maybe 1/2 GB.
Old 07-01-2008, 07:27 PM
melbourne tim's Avatar
C220CDI
I'm having difficulty recording songs from a CD to the internal hard drive. It says "no music files", and the CD's are genuine ones purchased from a large store. Does anyone else have the same problem?
Old 07-01-2008, 08:32 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
I've been able to rip CD's to the car's hard drive no problem.
rs1985: SDHC is not backwards compatible with older SD card readers, so that's likely why it is not reading in your computer. You'll need to get a SDHC card reader. If you computer supports SDHC then maybe your card is bad?!
Songs purchased off of iTunes can be converted in to MP3's through iTunes BUT you don't want to because it will sounds like an old cassette or radio quality.
To the OP, is your card reader SDHC compatible? SD & SDHC cards are in the same form-factor so it may fit in there but no actually work. I have a SDHC compatible PCMCIA card reader and it works 95% of the time. Once in a while I will get the "No playable files" error message, but I simply pull out the SDHC card and stick it back in the PCMCIA reader (without removing the PCMCIA card from the car's slot) and it works again. Odd but I'm fairly certain it's that my PCMCIA card has finicky connections inside of it.
Old 07-22-2008, 10:01 AM
Dimebag Darrell's Avatar
Mercedes Classe C
Hi all,
Please make a list of PCMCIA 6 in 1 card (with URL if possible) compatible
share your experience with the others users
Best regards,
Old 07-22-2008, 10:15 AM
C220CDI
Originally Posted by Dimebag Darrell
Hi all,
Best regards,
The best way really is to search ebay. I can't find any of these in any retail store. I bought one but unfortunately it is not SDHC compatible. I'm still able to use it with a 2G SD card, just not with anything bigger.
Old 07-22-2008, 10:41 AM
maverickvii's Avatar
2008 C300 Sport 6M
Does anyone know what filetypes are supported. MP3, WMA....does AAC or Real Audio work?
Old 07-22-2008, 10:55 AM
C220CDI
Just MP3. Nothing else!
Old 04-27-2010, 12:45 AM
Pete7874's Avatar
'08 C300 4Matic Sport, '02 530i
According to the owner's manual, WMA and WAV files are supported as well.
Old 04-27-2010, 12:53 AM
Robbio204's Avatar
C350
I have been able to use only mp3 files. Also, I think there may be a size limit, so consider that too. My setup is a 6-in-1 adapter and Sandisk 2 gb SD card fyi.
Quick Reply: No playable files? Memory card
