S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Bumper removal & chrome replacment
Old 05-09-2008, 01:20 PM
94E420's Avatar
2006 SL500
Question Bumper removal & chrome replacment
I want to remove my front bumper and replace the chrome on my 1989 560SEL. Has anyone done this in here? Is bumper removal difficult?
Old 05-11-2008, 10:47 AM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
[QUOTE=94E420;2814458]I want to remove my front bumper and replace the chrome on my 1989 560SEL. Has anyone done this in here? Is bumper removal difficult?[/QUO
I did this about 5 years ago on a 1991 560SELwhich I no longer own. The removal is relatively simple. There is a bracket that you can see in the front section of the fender well on each side. Take the bolt off. Then at the front of the car the bumper is attached to the bumper shock absorbers. I don't recall how many bolts hold it on but remove all of the bolts and the bumper pulls straight off. Removing the chome is easy but before you do it make sure that you have new mounting brackets since the old ones are probably going to be rusty. The process of removing and replacing is tedious but not all that difficult. I posted the precise steps to use a few years ago on either www.mercedesshop.com. or on www.benzworld.com
Old 05-15-2008, 07:52 PM
Thebenzismine's Avatar
1990 mercedes benz 300 se
Im thinking of changing the chrome on my rear bumper im starting to see some rust
Old 05-30-2008, 12:31 AM
granit560's Avatar
1987 560 sec impala metalflake, over cream, or java.
im just in the proses, taking the bumper off ect., its easy enough. 6 bolts, 2 on each side under the car, 1 on each side from up top hwich you can see if you look through the opening under the grill. if thes are rusty its not that easy, mine were like the day they were put on, also this will probably be an indication of the difuaculty youl have seperating the shroud, & the 3 crome pieces. ( also youl have to unplug the driving lights somewhere around the signal lights ) mine were no rust whatsoever & believ me its a job. i would hate to have even 1 stuborn screw.there are 12. be prepared to replace them due to damage if this is the case. just my 2 cents
Quick Reply: Bumper removal & chrome replacment
