Old 06-04-2015, 06:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Specifications and General Maintenance
Print Wikipost
Does anyone know how to Reset Service indicator for 2008 C300?
Old 04-30-2008, 08:38 AM
Darryl1Nation's Avatar
C300 - Black
I called my local dealer and asked.. and they said it was against policy to tell anyone.. so they could do it for me for 52 bucks.. what a rip off. I had a C230 and I was able to reset the service indicator on that one because it had a reset button that u can actually push in.. when u turn the key to the ON position then hold that reset button then turn off then back on.. it worked.
has anyone tried on the 2008 models??
Old 04-30-2008, 09:02 AM
ManchesterMerc's Avatar
2008 220CDI Sport Auto Estate, Obsidian Black, Black leather, Heated Seats,Pan Roof, Comand,
I understand that this has to be done by MB on the W204. I'm sure if anybody knows any different they will be along to tell you
Old 04-30-2008, 11:59 AM
webada's Avatar
528i, GLK
i didn't know that c230 can do that, but I believe w204 needs a obdii reader to reset defaults.
Old 04-30-2008, 02:17 PM
Derspeed's Avatar
X3 and 2012 C coming soon
We use a service reset tool for BMWs and VWs. I don't know who sells them for Mercedes. I'll check into it later.
Old 04-30-2008, 03:51 PM
chilledbenz's Avatar
2008 R350 & 2008 C300
Ha ha this is going to sound like a wasted post but somewhere on this board someone posted how to get into the service menu to reset it. Something about holding the mute button and something else on the steering wheel. There are quite a few people here changing their own oil so someone will post soon I imagine.
Old 04-30-2008, 05:47 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
Secret Menu
********Make sure your door is closed*********
1.Turn your ignition in first position
2.Press and hold the accept call button for 5 seconds and while pressing press the ok button on the steering wheel.
3.If needed after releasing the two buttons press ok once more.
This should allow you to reset and it also the secret way to completely disable ESP (not recommended unless you want to spin out of control and burn through your tires). Be careful!
I claim no responsibility for any damages to car, people, or personal property
Old 05-06-2008, 05:42 PM
opp
opp's Avatar
2008 C350
Works like a charm!@!@@ thanks- !@!
Old 05-06-2008, 09:17 PM
crow944's Avatar
2008 Calcite white C350, Command system, 3M clear bra, tint 30%
Will this work on the C350 too?
Old 05-07-2008, 09:30 AM
opp
opp's Avatar
2008 C350
Yes i have the 350
Old 05-07-2008, 11:52 AM
hans99201's Avatar
C350
I tried this and had no success. ??? So I put the ignition in the first position and then pushed the call button and the ok button on the steering wheel at the same time and nothing happens. Can some one help?
Old 05-07-2008, 04:58 PM
opp
opp's Avatar
2008 C350
dude- doors closed-
press the ok- twice.
Old 06-05-2008, 03:21 AM
delirium's Avatar
C350
worked for me, thanks!
Old 06-06-2008, 12:27 AM
RLE
RLE's Avatar
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Uh uh
<<dude- doors closed-press the ok- twice.>>
Just cycles through the odo reset window.
Old 06-06-2008, 02:23 AM
CE EXO's Avatar
C200 AMG W204
http://www.youtube.com/watch?v=3tLtaMPS46o
Go to this link its for deactivating the esp but works also for reseting your service data.
Its a hidden menu that pops out if you follow the intructions of the video.
Old 06-06-2008, 02:40 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
This happened to me also but it came good in the end.
Close Door.
Key in Ign.
Turn key to 1st position.
Press both Phone answer & OK button on Steering wheel simultaneously.
Wait 5 seconds.
Good luck from Aussi.
Old 06-08-2008, 11:31 PM
C300Man's Avatar
C300
not sure what I'm doing wrong here, I placed key in first position, door close, press phone icon ( not hang up icon ) and press the ok button and hold but nothing comes up. What am I doing wrong I have c300. Thanks
Old 06-09-2008, 01:10 AM
CE EXO's Avatar
C200 AMG W204
Press first the accept call button leave one second (with the accept button pressed)and then press the ok button and hold them both for two or three seconds that will do it.
Old 06-09-2008, 08:24 AM
E350 Sport/ML350RWD
1st: Get in
2nd: Close the Door
3rd: NOW put key in ignition
Get it?
4th 5th and so on
Old 06-09-2008, 12:19 PM
che0x's Avatar
C300 Sport 4Matic
Originally Posted by AkaSigFreak
1st: Get in
2nd: Close the Door
Get it?
4th 5th and so on
Did it exactly as described and it just gets me to the trip odometer reset screen.
Does this just work with early 2007 C300's? Mine is a C300 Sport 4matic purchased in March 2008.
Old 06-09-2008, 12:32 PM
E350 Sport/ML350RWD
Everyone who has tried this step by step and follows the directions precisely gets it to work. I just got up (arm in splint/sling from major shoulder surgery) went out to my car and entered the Vehicle System Data screen which also had the option for the dynamometer mode to turn off traction control for Dyno testing. A while back I was messing around and tried for like 20 minutes and was very frustrated because I had done this before with success. I finally shut the stupid door and everything worked. I don't think it has anything to do with when you bought your car (my build date was Nov 07 in Germany).
Old 06-09-2008, 03:31 PM
che0x's Avatar
C300 Sport 4Matic
Do you have to exceed the service interval criteria (time or mileage) for the reset option to appear?
Old 06-09-2008, 10:34 PM
E350 Sport/ML350RWD
I'm not sure (my service isn't due yet)
Old 06-09-2008, 11:13 PM
RLE
RLE's Avatar
Service screen
..Everyone who has tried this step by step and follows the directions precisely gets it to work....
Well, not quite everyone. I too cannot bring up the screen using the instructions posted. Even though my car is fairly early (9/07 production) it seems unlikely that would be a factor. I will inquire at my dealer this week and they will tell me.
Old 06-17-2008, 12:33 PM
rgrpc's Avatar
2008 C300
I got it to work after I reset the odometer to 0.0, then I pressed the call button a bit before I pressed the OK button then presto
Old 10-06-2008, 06:56 AM
cietdu's Avatar
C
For me, it only works if I press and hold the call button BEFORE pressing the OK button.
Quick Reply: Does anyone know how to Reset Service indicator for 2008 C300?
