E-Class (W211) 2003-2009
'05 E500 - water inside the trunk LID?
Old 04-23-2008, 02:39 PM
ss3964spd's Avatar
2011 E550 (RIP), 2014 CLS 550C4
That's right, not inside the trunk, inside the trunk lid.
Got a bunch of rain here in Northern Va on Sunday. Opened the trunk for the first time last night since Sunday. My 14 year old heard the sloshing before I did.
I haven't had time to look for possible entry points. Has anyone heard of such a thing?
Thanks,
Dan
Old 04-23-2008, 05:10 PM
jallison12's Avatar
2004 E500 Wagon 4Matic
Me no have a trunk
But good luck with your search.
Old 04-23-2008, 06:11 PM
konigstiger's Avatar
Received 4,417 Likes on 3,146 Posts
'71 Pinto
It may be the plate recess panel. See #210 in the diagram.
Old 04-23-2008, 09:49 PM
E320joy's Avatar
2015 S550
same problem
Yes, one time when I had mine detailed they told me they found the water in there when they vacuumed the trunk. Same thing, the water was not in the trunk itself, but in the lid. I have not had the problem since and attributed it to the fact that they were using a water under high velocity and pressure. I did not give it any more thought until I read this. Perhaps you should check with the dealer and see if others have had the problem.
Old 04-23-2008, 11:11 PM
ss3964spd's Avatar
Plate recess panel - yup, that could be it.
It appears that it eventually drained out from the rain we got, but I washed the car this evening and it did the same thing. If I pull on the lower edge of the plate recess panel I can get it to dain faster - otherwise it just drips out until it empties.
Fortunately it seems easily reproduced. Only place I can think that it would be getting in is at the upper seam, which runs the length of the trunk lid, where the panel meets the trunk lid.
Dan
Old 04-24-2008, 08:19 PM
E500 Benzo's Avatar
2003 E500 Sport, 1995 SL320
+1 happens to me all the time. i checked and it looks as if the recess panel is in fact the culprit.
Old 04-30-2008, 10:10 PM
unitfreebie's Avatar
2006 CLK 350 Fog City, CA, USA
Yup! The diagram shows the license plate recessed subpanel as a separate attachment to the trunk lid. I wonder how many screws holds it on and is there a rubber gasket???
Definitely a collusion or damage to the rear portion of the Trunk Lid could cause a leakage in that subpanel area. Maybe just slamming down the trunk lid really hard could cause the panel to bend enough to let water get throuigh?
Old 05-01-2008, 10:27 AM
ss3964spd's Avatar
There hasn't been any damage to the car. Dealer says they attempted a fix but it obviously didn't work. The diagram above does not show any kind of a gasket.
While it's interesting to know that others here experience the same issue I've yet to hear from anyone with a fix. Might be something I have to tend to myself.
Thanks for the feedback,
Dan
Old 05-03-2008, 03:05 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
Open the trunk lid...see the sponge type stuff where the drain is. It gets clogged with dirt and doesn't drain properly. Pull it out. Problem solved.
Old 05-04-2008, 12:25 AM
Thumbs up
Wow ! There's a drain hole in the Trunk Lid??? Time to call the Roto-Rooter Man !!!
Old 05-05-2008, 10:54 AM
ss3964spd's Avatar
'Eh, I see neither drain or sponge type stuff.
Can you help me get a clue by describing where the drain is? I'd think it would have to be at the lowest point of the lid when the lid is closed.
Thanks,
Dan
*EDIT* Doh. I found it. Dead center, bottom edge of the lip. I'll either take the rear panel off and clean out the filter, or just dig out the filter.
Thanks Technician.
Dan
Old 04-08-2012, 05:41 AM
Mantooth's Avatar
2004 E55 AMG
Awesome, thanks! I'll look into this when I get home.
Edit: Old thread, but great information!
Old 04-09-2012, 10:41 AM
KEY08's Avatar
Received 1,616 Likes on 1,186 Posts
2014 E550-sold 😩
I dug my sponge out of there years ago for the same issue. Mine collected so much rain water the trunk would not stay in the up position.
Old 03-09-2015, 01:10 PM
Yojik's Avatar
Mercedes-benz CLK320
Hi guys,
do any idea why this hole is in the trunk?
water is coming in during rainy weather - the car is E350 2005 model.
Old 03-20-2019, 02:29 AM
E-SWAG77's Avatar
E500
Water 💦 in The trunk.
My problem was the tail light on the truck. The gasket around the light wore out.
Thanks,
Dan
Quick Reply: '05 E500 - water inside the trunk LID?
