2006 C230 "Turn Signal, Left Mirror" warning light?
Old 02-11-2008, 01:02 AM
axhoaxho's Avatar
Greetings,
I did a search but still have some questions...
My wife's 2006 C230SS just showed a "Turn Signal, Left Mirror" warning signal in the dashboard display. I tried to activate the left turn signal, the dash ticker sounded in a little faster 'tick tick tick', and the LEDs in the left mirror were not lighting up.
My quick questions are...
- Does it mean that the LEDs are burned out (I thought LEDs have long life) or some bad connections?
- Can I replace the LEDs myself or I need to visit the dealer service department (the owner's manual said visit dealer)? If I can do it myself, what are the procedures?
Thanks for any help
With best regards,
Old 02-11-2008, 01:20 AM
nickgailloux's Avatar
2005 Mercedes C230 Sport Sedan (W203)
https://mbworld.org/forums/showpost....7&postcount=27
Old 02-11-2008, 01:54 AM
axhoaxho's Avatar
Thanks very much for the link.
With best regards,
Old 02-11-2008, 08:58 AM
axhoaxho's Avatar
Oh, one more question... I assume that the mirror turn signal LED is not covered under warranty? If yes, then I would just head to the dealer parts department for a new one and replace it myself...
Thanks, and with best regards,
- Alex.
Old 02-11-2008, 10:49 AM
06c230hwd's Avatar
06' C230SS
diodes are longer life. yet they are only as good as the circuit they are connected too. bad connection, lots of vibration, theyll go out. led's dont go out all at once as far as i know though.
Old 02-11-2008, 01:43 PM
jfabes's Avatar
'07 GTI & '04 M3
i had condensation in my drivers side mirror signal lens, took it to the dealer and they replaced the lens unit under warranty.
the service advisor said that some dealers do not replace due to condensation, led's out, etc., but some do....so, i would make a call before taking it in.
also, with regards to the led's...led's usually burn out individually. if the whole group is out, than its prob a diff problem...like the led circuit board, fuse, or soemthing along those lines. that should def be covered under warranty as its not simply a "wear and tear" item.
Old 02-11-2008, 06:50 PM
axhoaxho's Avatar
Thanks folks,
After seeing your feedbacks, I guess I am going to let me dealer take a look of it first. I will keep it posted. Thanks again.
With best regards,
- Alex.
Old 01-06-2011, 04:56 PM
drho2004's Avatar
2005 C230 SS
hello
reviving an old thread here but the same thing just happened to me on my 2005 c230k. For a few weeks its been giving me an error saying that the left turn signal mirror was out. it wasnt, kept working just fine until this morning when its actually gone out. im just wondering what is the cost of purchasing the unit from the dealership? or can it be bought elsewhere?
Old 01-06-2011, 05:06 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
They're about 25 each side on RM European. Dealership would be more, of course.
You can sometimes pick them up in the classifieds, as people switch them out for other versions. People switch more than partners at a West Virginia family reunion.
It's a fairly simple swap; the second one will take you about 3-5 minutes to do. The first one will be substantially longer, until you realize that it's much easier to do than you think.
Old 01-06-2011, 05:13 PM
drho2004's Avatar
2005 C230 SS
thank you so much Tommy! i will check this out, tackle it and see how it goes
Old 01-07-2011, 04:37 PM
drho2004's Avatar
2005 C230 SS
wow
that was weird, the blinker light works today again. just out of the blue.
hmm..what else could it be? bad connection? computer error?
Old 01-08-2011, 11:02 AM
vdemon311's Avatar
2006 c230
This happened on my 06.. one day everything perfect.. next day I would get the light.. day after that perfect... Then again a message the next day. I removed the mirror to check everything. When putting it back on, I had my brother help and make sure the connections were "snug". Basically forcing it in as much as possible. No message since then. You will usually hear a small click when its in place. I read on a few other benz forums that this is a common problem in the w203 and that it is indeed just a connection failure. Apparently bumps, vibrations, condensation, etc. tend to cause the connection to come loose.
Old 01-10-2011, 03:57 PM
drho2004's Avatar
2005 C230 SS
ah i shall check it out when i have time. yeah it seems like a connection issue
Old 02-12-2011, 10:09 PM
spentHO's Avatar
2006 C230 (203.052 m272.920)
I am experiencing the same problem in my 2006 C230 and the problem has come and gone for a while now. The odd thing though is that if have my turn signal on, the blinker will blink and make the clicking sounds rapidly...Well if i happen to roll the window up or down the blinker slows down to as if there was no problem and then resumes the fast flashing/clicking after the window rolls up or down. Hopefully that just made sense...I was thinking that it might be related some how to the window switch but i guess i need to check the connections on the mirror's LED before doing anything...
Old 02-13-2011, 02:17 AM
jerryml430's Avatar
2006 c230
Originally Posted by nickgailloux
how come i can't see the pictures?
Old 06-21-2011, 12:08 PM
djstylzmlr's Avatar
2006 C230 Sport
Can see pictures...
Old 12-14-2011, 03:42 PM
milindn's Avatar
2006 c230
I do not see any pictures either. Can someone please help...
Old 12-14-2011, 04:35 PM
phister's Avatar
06 C230 SS 6spd
its usually the wire on the harness is either bent, cut, or exposed grounding out. You can actually put the mirror forward (toward the front of the car) and see the wiring. You can get some electrical cleaner and spray it and see if it'll help. If know you'll just have to remove the mirror and replace the harness.
Old 01-19-2012, 02:51 AM
Jerkin's Avatar
C230 Coupe Silver
Phister, your car is really nicE haha. But the reason I'm assuming the turn signal clicks faster is because the circuit is setup to give a certain amount of power towards the lights but because one light isn't working, means the circuit gets finished faster therefore it can begin again faster.
I checked this when pulling my rear turn signal bulb, and once again wIth the front turn signal
rwolak (07-27-2021)
Old 04-18-2012, 02:13 PM
BlkBenz8's Avatar
07 C230 (sold) 2009 E63 AMG (SOLD), 2015 E 63 AMG S
I need to replace my turn signal but the pics arent showing
Any other links??
Old 04-18-2012, 02:49 PM
tommy's Avatar
Here's an oldie but a goodie on removing the mirror cover.
https://mbworld.org/forums/c-class-w...r-removal.html
Once you've done that, it's just remove a couple of screws and remove the light strip. Piece of cake once you know how.
EDIT: I notice that it's in the same thread as the post you provided above. Only thing that's not shown is the removal of the light strip, but as stated, it's simple.
Old 04-18-2012, 08:35 PM
BlkBenz8's Avatar
Thats weird, i just went to go check to see if the instructions matched the model but they dont.. I dont have that silver clip.
Old 04-18-2012, 09:57 PM
ValerSterling's Avatar
bmw
Old 04-18-2012, 10:35 PM
04mbc230's Avatar
2006 C230 Sedan
yup. Condensation is one of the issue that cause this error to show up on the dash board.
Old 04-19-2012, 10:08 AM
tommy's Avatar
Can you post a pic of your mirrors with the guts exposed? There has to be a release tab somewhere. I'm assuming they're the original ones, right?
Quick Reply: 2006 C230 "Turn Signal, Left Mirror" warning light?
