S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Best year for w126 diesel?
Old 02-04-2008, 09:01 AM
david42's Avatar
BMW 328i
Hi all,
I'm in the market for a w126, long wheelbase. I don't need a fast car, but I do want one that will last a long time. I'm pretty sure that means a 300SDL is the right choice for me, though maybe I should also consider the 300SEL?
I know that Mercedes sometimes makes small--but important--changes in their engines. Is there a particular year that is more (or less) trustworthy than others? I'm open to either 5 or 6 cyl models. As I said, longevity is more important than speed for me.
I don't expect a "good year" to substitute for good maintenance. I just want to know if there are any rules of thumb, along the lines of "beware of 350SDL," etc.
-David
Old 02-05-2008, 11:09 AM
Blackfield's Avatar
560 Sel
Hi I have 1986 560 SEL with 79k original miles for sale. If you are looking for a reliable and a car that will last you for many many years to come then this is your best bet. Let me know.
My email: khwaja1@gmail.com
Old 02-11-2008, 01:40 AM
Diesel's Avatar
Mercedes 2019 AMG S63, 2015 E250 Bluetec. Previous: '18 E63S, '07 E63, '10 S550, '15 S550, '10 GL350
1987 300 SDL Turbo on Eaby
Check out this ride:
http://cgi.ebay.com/ebaymotors/Merce...em130195362977
Old 02-23-2008, 02:43 AM
benzmanca's Avatar
1986 560sel
SDL is the best bet in the diesel the SD is under powered at 5cyl. Most would recommend w126 gas powered. It is a smoother ride, the problem is finding a w126 that is not over priced, and is in good condition. Good Luck!
Old 02-23-2008, 01:11 PM
whoover's Avatar
'19 E63S sedan
You do need to be on the look out for engine problems with the six, however. See the "Problem models" section:
http://en.wikipedia.org/wiki/Mercedes-Benz_W126
Old 02-23-2008, 02:18 PM
Untertürkheim's Avatar
Depending on how long you want to keep the car, you can buy a 350SDL with a blown engine and have it properly rebuilt. It should run forever after that, as long as you take good care of it.
Old 03-09-2008, 11:52 AM
hineywineries's Avatar
It changes all the time
If you really want a long wheel base, the 5 cyl is not an option. Only the 6 cyl came in the long wheel base starting in 86. Whether you go diesel or gas depends on your driving. If you are going to putz around town, get the 300SEL. If you are going to do more long distance or commute driving, get the diesel.
P.S. I noticed you are driving a 328i right now. Once you start driving a Mercedes, you'll probably give that Beamer away.
Rate This Thread
Rate This Thread:
Quick Reply: Best year for w126 diesel?
