Fuse Box Map
Rating: Thread Rating: 5 votes, 5.00 average.
Old 01-25-2008, 11:20 AM
StephanieDecker's Avatar
C230 Kompressor
Fuse Box Map
I need a fuse box map for my 2002 C230K. I could not find the map on the fuse box on the inside car (drivers side). Does anyone have a scanner. Or can anyone tell me which fuse controls the left side headlight turn signal. Thank you for your help.
Old 01-25-2008, 12:38 PM
PeteyV's Avatar
W203 C230, W210 E350, W166 ML63
If anyone can do this it'd help me out alot too. I dropped a coin in my cig lighter a few months ago when i took out my cell phone charger and ever since then its been shorted out. I dont really feel like going to the dealer for them to just change a fuse. So if anyone could help me out on this too I'd appreciate it
Old 01-25-2008, 05:16 PM
BabyBenz6spd's Avatar
2005 C230 Sedan 6spd
You are lucky I still have this image file in my computer from while I was hardwiring my 8500 Escort awhile back =)
Hope this helps~
Old 01-25-2008, 10:30 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Everyone should have that piece of paper, it's tucked inside the driver's side fuse box. It even has its own little plastic holder
Anyone else notice we have a fuse for "Fanfare"?
Old 01-26-2008, 10:10 AM
C230 Kompressor
Thank you soooo much Babybenz
Old 01-26-2008, 06:30 PM
No prob~
Old 02-01-2008, 09:16 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
thanks for sharing
Old 02-10-2008, 11:23 PM
14bop's Avatar
2001 c200 kompressor avantgarde
LHF indicator
Hi,
What was the outcome of the lh front headlight not operating. After looking at the chart it says that the lh front indicator isnt a fuse its electronic??
Anybody got any ideas. My lh front headlight indictor stopped working and gave a fault indicator on the dash. THe bulb is fine as is the connections from the bulb holder to socket and harness to headlight assy.
any ideas would be greatly appreciated.
Old 04-01-2008, 02:21 AM
p51aviator's Avatar
My cig lighter has been out for like a year, and it has been driving me NUTS trying to find the fuse!! THANK YOU!!!
Now - why did they put the fuse to the lighter under the hood, when it's SO stinking easy to short it out with pennies in the first place?
Old 04-02-2008, 02:21 PM
C230 Sport Coup's Avatar
Ha! OK, not to hijack the thread, but it's funny you should mention this.
https://mbworld.org/forums/showthrea...04#post2743004
Old 08-03-2008, 02:38 PM
server_account's Avatar
E-220 CDI
E-class fuse map
Hi, does anyone have the fuse map of E-class (the 2003-2007 models). Thanks
Old 08-03-2008, 10:38 PM
Have you tried posting on the E-class forums?
Old 08-05-2008, 05:33 PM
aznmode's Avatar
2010 c300
Does anyone one know what size fuse is supposed to be for the horn? It's #43 in the fuse box under the hood. Does it go in 43A or 43B? Mine was missing already when I got the car 2nd hand. Any help is appreciated. TIA!
Old 08-05-2008, 06:33 PM
Kal Rubinson's Avatar
2002 C320 Sport Wagon
Great idea. I have the map but will scan it anyway as insurance.
Kal
Old 11-16-2008, 04:27 PM
tmo1113's Avatar
2003 SL55
does anyone have the Fuse map for 2003 SL55 ?
Old 10-04-2009, 03:39 PM
boyang81's Avatar
2005 c230 kompressor sedan
hi I am new to this , can any one tell me where is the fuse box located ?? I have a hard time to find it ...
Old 10-04-2009, 04:14 PM
Super Moderator
samaritrey's Avatar
THE C350
go look at the first pic posted it has a diagram showing you where all the boxes are.
Old 10-04-2009, 07:17 PM
boyang81's Avatar
thanks for the reply samaritrey , I do see the pic where the box is .. but when I going to the car I don't know what do I have to take off b4 I can see the box ... is there a cover I need to take off b4 I can get to the fuse box ?? please info ... thank you again
Old 10-04-2009, 07:25 PM
boyang81's Avatar
thanks again . just find out I can use the quote button lol .. please be more speci ... do I need to take off some sort of cover ??? my problem is that my radio works ... but when I try to turn up the volvume it won't be as loud as b4 ... and also when I try to adjust bass or other stuff it won't responed ...sometime when I switch from cdc to radio am fm I can see the display for the station but no sound come out and I can't switch station , and nothing works don't matter what I press .... I been reading some of the post when ppl take out the fuse and reset the radio to fix the problem so I want to try and see if that will work on my case ... just bought the car for 1 month . it's out the warrenty .. I know that suck .. so I am trying to DIY all the way lol ..... long story short it all happened after my friend hit a bump on the road and ever since then my radio don't work right .....so please help .....it's my first benz lol
Old 10-04-2009, 08:30 PM
Super Moderator
samaritrey's Avatar
THE C350
ok read this https://mbworld.org/forums/c-class-w...und-radio.html. if you still need help let me know. the other fuse box is under the hood driver side firewall. remove the black cover by twisting the two fasteners. then their is a big black box with a few latches to undo then you have access. don't know where the radio fuses are and i am to lazy to figure it out i have done a lot of searching for people today. btw do you have hk. also please read the linked page fully before you ask me more questions. i see that you are in Rockville not that far away from me in McLean. i love coming to Rockville because you guys have a krispy kreme place their. lol but i won't go back because some idots decided to try and fup my dads slk55 amg in the parking lot while i was inside. lol all 5 of them got arrested.
Old 10-04-2009, 09:37 PM
boyang81's Avatar
yep read the post you have and my case I did find the fuse box and reinstalled fuse but nothing changed I do have a HK system hehe which is nice , and I did located the amp in the rear trunk passenger side . there is a fuse on top of the amp it's a 5amp fuse didn't do anything to it yet ...when I check the sound still can't turn up loud as b4 , and also there is delate on the volume control . when I turn it all the way up the sound will turn up loud but with a second delate .. and there is craby noise from the center speaker above the dashboard .... it's as I have too much bass for the speaker to handle type of sound if you know what I mean .... cd changer plays normal but sometime I have to switch cd back and forst to get it work ...do you think I need to take out the head unit and check the connection in the back ?? and also would be a blowed speaker in the center ?? and the the weird thing is I can't adjust bass or suround sound .....or fade ..... verything else works fine ...... so strange ....
Old 08-12-2010, 08:09 PM
edgarinho10's Avatar
2013 UFO
2 years 6 months and 17 days later your still saving lives BabyBenz6spd
Old 08-12-2010, 11:29 PM
omg its nate's Avatar
06 C230 6 Speed FTW
Well just in case I saved the images,
Old 01-14-2011, 04:18 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
Sorry to bump this old thread up but.. The drivers side interior fuse panel, where in the car is it located and how to get to it because the picture makes it look like it's in the door.
Old 01-14-2011, 04:50 PM
pcy
pcy's Avatar
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
look at the side panel (that's parallel to and next to the drivers door) of the drivers side dashboard. Use a flat blade screwdriver and pry the cover and you will see this...
You are looking at the side view of the headlight switch and the fuse panel.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: Fuse Box Map
