Size of nut on the battery terminal?
Old 01-18-2008, 04:48 PM
LetsJet's Avatar
355 F1 Spider & ......V12 w220.176
Anyone know or point me in a direction to find the nut size for the battery terminal? I have an '04 S600 but I would guess they are all the same.
I want to connect my Battery Tender directly instead of using alligator clips.
Old 01-18-2008, 11:18 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
10 mm, use a deep well socket and 1/4" ratchet.
Old 01-19-2008, 02:09 AM
LetsJet's Avatar
Thanks,
Though, I might not have been clear. I need the nut size and threading. I know the nut on there now takes a 10mm socket. I want to thread another nut on the bolt to attach the battery tender. What nut do I look for at home depot?
Old 01-19-2008, 05:47 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Originally Posted by LetsJet
Thanks,
a 10mm nut has the same thread pitch
If you just use a 10mm nut you should be okay. The bolt is a 5 or 6 with a 1.5 thread pitch.. These are common metric hardware so if you just look for a 5 or 6mm ( i can't remember )nut it should work fine.
Old 01-19-2008, 06:50 PM
LetsJet's Avatar
I'll get both if I have to and report back
Old 01-27-2008, 09:19 PM
LetsJet's Avatar
I can confirm that it is a 6mm nut.
Old 10-24-2012, 12:13 AM
Das Geld 2's Avatar
SL55, S500
The 10mm nut was way too small to fit..
Quick Reply: Size of nut on the battery terminal?
